ef9 no power a little help
Old Jan 30, 2012 | 09:30 PM
EF9_RIDER37's Avatar
Default ef9 no power a little help
What up so this is the situation with my hatch. I was driving my car and all of a sudden the check engine light came on, then when i was trying to power it was acting like it was out of gas, now my car doesnt get power to anything battery is good and grounds are good thermostat is there battery ground also and also transmission one too. Some help would be helpfull im at a lost thanks guys
Old Jan 31, 2012 | 03:53 AM
crvtectim's Avatar
Default Re: ef9 no power a little help
Retrieve codes and check fuses, then report back.
Old Jan 31, 2012 | 09:54 AM
Fuses good and can't get codes I get no power at all to nothing
Old Jan 31, 2012 | 11:29 AM
efstunnin's Avatar
is it obd0 or obd1
Old Jan 31, 2012 | 04:46 PM
Obd0
Old Jan 31, 2012 | 06:00 PM
efstunnin's Avatar
the ecu should be underneath the passenger carpet by the firewall
there should be an led light in the middle
and it will blink
turn the key to the on position and see if it starts blinnking
thats how you check your codes
Old Jan 31, 2012 | 06:01 PM
efstunnin's Avatar
also check the ecu wiring
make sure its all plugged in and tight
also check under the hood fuses and check dizzy wiring
Old Jan 31, 2012 | 08:44 PM
Checked it all dizzy wiring good fuses are good ecu is good and as far as blinking whem we turn the key into the on it blinks once and that's it no blinking after that to retrive codes and I get no power to anything to the dash or lights
Old Feb 1, 2012 | 05:41 AM
efstunnin's Avatar
try making sure the battery is fully charged
does it make one short blink or a long blink
each long blink is 10 and every short blink is 1
Old Feb 3, 2012 | 05:36 PM
Short blink
Afshin9393
Nov 24, 2011 08:03 PM
Beau Gotti
May 16, 2006 06:36 PM
MrMayhem
Nov 22, 2005 07:54 PM
vangboi_209
Nov 1, 2005 01:00 PM
EKRacer
Mar 28, 2004 02:27 AM
