Easy motor swaps?
Hello, I have a '93 Civic DX (D15b7). The engine in it is about to go. I need to throw another engine in it. I'm having a hard time finding any D15b7's in my area that dont have 200+ thousand miles. What other engines would be pretty straight forward swaps. I'm probably going to be paying someone else to do it for me so I'd like the swap to be as easy as possible. Thanks in advance for any info/help.
Japanese Domestic Market (JDM).
everything made/imported to japan is referred to as JDM Parts. (example: Honda Civic Type R)
same goes with anything made/imported to the united states (USDM)
with most things automotive, especially honda's (obviously being a japanese company) nearly everything JDM is superior and even the in places like Europe (EDM) and Australian (AUDM) are still better especially in the engine category mainly because the much stricter safety and emissions standards in america.
for example you would get more stock horsepower out of a JDM B16 than a USDM B16.
these shops have distributors over seas that ship parts to america, for hardcore fans or who want the very best.
There are also B-series engines in the 1999-2000 Civic Si, 1994-1997 del Sol VTEC, Integras, and CRVs that will fit in there, as will H-series engines from Preludes.
The cheapest swaps would be another D-series from another Civic though.
I put a 2000 GSR (B-series DOHC Integra engine) into a 1998 Civic EX (came with a D-series SOHC) and it was extraordinarily easy though. Pricier than a D for sure.
I believe what this guy means when he says "JDM shop" is a tuner shop. That is, a garage that modifies cars, specifically focusing on Hondas, Toyotas, Subarus, Nissans, etc.
if you want the easiest and most streight forward, i would drop in a d16z6... everything bolts right up and you really dont "need" to change anything..
What i mean by "need" is that it would be advised to change the engine computer... the one you have will work, but the z6 is a VTEC engine and you ecu will not be able to use it. You would just need to swap out yours for a p28 ECU and get a vtec conversion harness (cleanest look, other than changing the whole harness) That harness is just 2 wires, one for the VTEC solenoid and the other for a oil pressure switch, just run them through the firewall and hook them into the ECU plugs... should be able to find a thread somewhere on it, as thats what i had to do to mine.
Personally, if you are mechanically inclined... unless the z6 has really low miles, i would rebuild it anyway before dropping it in, just to be on the safe side..... of course, i would also do a proper build in it... but thats a different story =p
The question is how much do you want to spend? If you just want a replacement why not look at 96-00 D16Y7 engines. You can reuse all your stock ECU, manifolds, distributor, injectors, and alternator and will probably be able to find lower miles. If you want to spend a little more you can use the D16Z6 but you'll want to make sure you pick up the ECU and distributor for it if it has it. Those are the two easiest without ordering a motor.
no, JDM shops exist in america, they get shippments from japan businesses to sell to american customers, they are pretty much a middle man. they are into hardcore proformance and carry brands like honda, nissan, toyotas, ect
Most D-series engines from 1992-2000 Civics will fit in there no problem. To be legal it needs to be the year of your car or newer.
@HondaPartsHero I'm not looking to spend too much. This is just my back and forth to work car. I drive 50 mins to work everyday. Gas milage is more important than power in my case. I'm looking for whatever is mostly plug and play. I definitely like the sound of the D16y7 and the D16z6. I will look into see if I can find any of these in my area. Sounds like it would be pretty straightforward correct? Will all my accessories off of my D15b7 bolt on to either of these new engines?
http://www.sunrisejdmmotors.com/engi...p?id=97&page=4
Will this engine go in my car easily? It's only $350!
@Jmaze its burning a lot of oil ( 1 quart every 150 mi!), the rings are shot on it. At least thats what a mechanic friend of mine told me, he tested it. Which is weird because the motor only has 100,000 mi on it. Anyway I was getting on it a few days ago passing someone and now it's running like **** and it sounds like somethings knocking in there. I just figured it about to commit suicide. I guess I dont really know what going on with it, but it sure doesnt sound good.
Does anyone have more info on the D15b Vtec-e engine? I've been reading more about it and I'm very interested due to the MPG numbers since I drive so much to work and I found one for so cheap. Is it an easy swap into my '93 dx? I found an ECU already and am ready to buy it if it's an easy swap. Any info is appreciated! Thanks guys!
After doing more reading the JDM D15B VTEC-E is the same as the USDM D15Z1. Does that help anyone shed anymore light on how easy it would be to swap this into my '93 DX?
It's not a particularly hard swap but there are a few things unique to a VX swap.
Further side note, I bought my D15B Vtec from sunrise a few years ago and haven't had any issues with it yet (I put over 100,000kms on it since I bought it)
- The fuel feed line needs to come from a VX, it's weird at the fuel rail end because it has to curve around the EGR valve, the one on the engine will most likely be cut.
- The EGR valve, you'll need to wire this in.
- The O2 sensor, VXs used a 5 wire wideband O2 sensor, the one on the engine will be almost surely damaged. These are very expensive, figure on spending what you paid for the engine for a replacement. Also, the VX ECU is very picky about the O2 sensor, most of the aftermarket ones don't work right, and it's directly related to the VXs fuel economy, so is the exhaust manifold.
- The ECU, the VX engine requires a P07 ECU
Oh. Thats good to know. Mine is an automatic so thats out fo the question. Thanks for the info. Looks like I'll probably be going with the D16z6 I found for 500 bucks. Sounds like the best option at this point. I found an ECU already on Ebay for about $100.
