Motor Mount Kit 92
I'm trying to figure out if there's a company doing a mount kit for the CB chassis using the F engine series and all i can find is the left & back from Hasport... would the right 94-97 fit aswell? where's the right one at...
Any ideas or options?
there is minimal demand or performance mounts for these cars due to age and less work being done on f series engines.
i personally never had a problem will all stock f22 mounts on a bolt on h22 with a 75 shot of nitrous, never needed the stiffer mounts even though i later added mount inserts.
as far as teh side mounts you usually do not need aftermarket mounts for the stock engine as they do not control engine movement or torque, they are just mounts to hang then engine and isolate vibrations. if your front and rear mounts are in good shape and control torque then you are fine.
i wouldbe curious to see what kind of set up NEEDS aftermarket mounts.
OP: looks like the guys at ESP have what you're looking for.
http://www.explicitspeedperformance.net/ESPHAMMK.html
and if you're not on here yet you should be:
http://cb7tuner.com/
H-series swaps use the same mounts as the F. also it seems that more is being done with F-series motors now than ever. it's possible that the CB7 chassis is slowly reducing in numbers, but last i checked this was one of the most widely registered vehicles from it's era.
I'm a new user so forgive me if this comment is out of place, I can't start my own threads yet.
I have a '92 Accord with an f22 engine in it, I need a new rear motor mount and I have a few questions before I replace it. I have heard from a few different people that the mounts from the h22 prelude match right up to the f22 and the rear one is even a little bigger. Also after doing some price checking it seems the price of the rear motor mount for the accord is way expensive. (Supply and Demand, I've heard these mounts go out a lot on accords)
So my question is would I be able to buy Motor mounts for the h22 and they would fit right up to my f22, maybe a little better? Also is there a good place to buy the motor mounts as a set? I'd rather just replace them all then one at a time.
if you have an automatic accord the rear mount is very expensive.
afaik there is not another mount you can put in there.
the lx and dx 5 spds have mounts similar to a prelude mount though.
Turbo-charged
Mar 11, 2008 04:24 PM
strictly.business
May 2, 2006 11:40 PM
Please answer this! as i'm interested too
