94 gas tank wiring problems please help :/
Old Jan 29, 2012 | 06:24 PM
sired's Avatar
Default 94 gas tank wiring problems please help :/
Ok so I just installed a harness into my delsol front to back... Now while plugging everything I've came across one problem.. Seems like the Fuel gauge sending unit connector isnt there, will I have Any problems with my fuel system when I go to try to start the car???
Old Jan 29, 2012 | 06:40 PM
lazlong's Avatar
Default Re: 94 gas tank wiring problems please help :/
You just won't have a fuel gauge reading. You can do several things: a) You can go to the pull-your-own place and clip the connector you need. b) You can get generic connectors. c) You can hard wire it (solder joint recommended).
Old Jan 29, 2012 | 07:26 PM
sired's Avatar
Ight then that's not bad just have to make sure I don't run out of gas 0-0
theEFkid
Mar 20, 2012 11:52 AM
vrrodri
Jun 29, 2011 05:32 AM
aquito
11
Jun 23, 2009 07:06 PM
crazycaucazian86
Apr 19, 2006 10:12 AM
phatstyles
May 29, 2005 11:59 AM
