PARK will not hold
Old Jan 29, 2012 | 05:43 PM
ndraised's Avatar
Default PARK will not hold
i shut off my car and could not get the key out.. i moved the car later and found out that when i parked on a small hill it would not hold the car.it made a clicking noise as it rolled backwards.
does the whold transmission have to be replaced to be fixed? and is it reliable to still drive long distance on?
Old Jan 29, 2012 | 06:45 PM
dglassmyer's Avatar
Default Re: PARK will not hold
More specifics on the vehicle always help, year, trim, etc.
However a fairly general suggestion would be to check the shift cable adjustment.
Here ya go.
Old Jan 29, 2012 | 06:55 PM
lazlong's Avatar
The PARK gear or pawl is worn. NEVER trust just the park gear, ALWAYS use the parking brake too. And no, the whole tranny isn't bad but, you'll have to pay some good money to have the park gear or pawl replaced because they have to remove the tranny and crack it open.
Old Jan 29, 2012 | 07:02 PM
dglassmyer's Avatar
By the way I've got a auto trans out of a 96 accord lx just sitting in my tool shed
Old Jan 30, 2012 | 02:05 AM
MAD_MIKE's Avatar
MM Gruppe B
Doubtful. Since the key could not be removed either it sounds more like the shifter is not in PARK.
ndraised scroll down til you see 'Key Stuck: Removing the key from the ignition switch or fixing seizing problem.' It's pretty much what dglassmyer posted. Peruse the page for anything else you may need to verify.
Cavemanug
Jul 25, 2015 06:11 AM
yingvang31
Apr 6, 2015 10:28 PM
bob001
Sep 20, 2012 09:46 AM
Ethan2536
Transmission & Drivetrain
May 12, 2010 11:48 AM
CRISIS
Aug 14, 2009 02:39 PM
