Updated List of Parts, Pistons + Rods, Blocks, KMS oil pump and Girdle ETC LOOK!
Old Jan 29, 2012 | 02:07 PM
TEG_SOL's Avatar
Default Updated List of Parts, Pistons + Rods, Blocks, KMS oil pump and Girdle ETC LOOK!
2 oem b series flywheels need to be resurfaced: $40 each
Used ARP B series flywheel and pressure plate botls: $80
ARP Head Studs bought new used on my motor fits B16 and B18C motors/heads: $80
Brand New, Never Used or Installed VISION Motorworks Adjustable Cam Gears & Gates Racing Timing Belt Combo For B16: $170
Aeromotive 11142 - 340lph Stealth Fuel Pump. Placed in my tank never ran. $150
Brand new Russell Stainless Fuel Line 92-95 Civic EX Si, Del Sol, Integra: $70
2X b16 blocks one comes with crank new crank bearings, oil + water pump, and various pieces and a turbo feed line. The other is the same but with no crank. Both blocks are bored for the 81.5 Supertech pistons I have for sale. one block has a golden eagle block guard and has no use on the new bore. The other block has a Supertech block guard and was used for 1300kms before tear down, also has golden eagle oil squiter plugs. $150 for block with crank, $100 without
B series alternator in perfect working order $100
Supertech 81.5 coated pistons only 1300kms on them hung on Magnitude Performance rods rated for 700 hp. Specs:
Set Includes: 4 Forged Pistons/Pins & Locks/Gas Nitrided Rings
Bore (mm): 81.50 mm
Oversize: 0.50mm +
Comp. Ratio: 9.0:1
Dome/Dish Volume CC: -2.5
Head CC's: 42.7
Comp Height: 1.181" (30mm)
Stroke: 3.047"
Skirt Style: X
Rod Length: 5.290"
Pin Diameter: 21mm (.827")
Weight/g: 235
Piston Part Number: P4-H815-N2
Ring Pin: GNH8150
Application: T/N
Pistons and rods are selling together. I will not separate: $500
92-97 Honda Del Sol Kteller Exhaust with Flowmaster Super44 all 3" $220
DEI 1" Titanium Exhaust Header Heat Wrap enough to do a header or downpipe with. Design Engineering’s new Titanium Wrap, using LR Technology, is capable of handling direct continuous heat up to 1800 degrees F and radiant heat up to 2800 degrees F.: $30
Old Feb 5, 2012 | 07:27 AM
TEG_SOL's Avatar
Default Re: Updated List of Parts, Pistons + Rods, Blocks, KMS oil pump and Girdle ETC LOOK!
Bump
Mynameisray
Oct 25, 2011 09:08 AM
h22_bb4
Mar 25, 2010 07:10 PM
subz326
Texas -OK -LA (Sales)
May 16, 2008 07:08 PM
