gsr disturbiator problem
Old Jan 29, 2012 | 08:40 AM
Ruy's Avatar
Ruy
Default gsr disturbiator problem
My gsr obd2 disturbiator stop working so i put a b16 disturbiator obd2 as well car turns on perfect only problem is When i step on it rpms go crazy up and down any thoughts only When i floor it
Old Jan 29, 2012 | 09:49 AM
Mr. EG's Avatar
Default Re: gsr disturbiator problem
Set the ignition timing
Old Jan 29, 2012 | 12:22 PM
mouab18c1's Avatar
Your rpm goes crazy? Did you ground at the thermostat housing come loose? Or the b16 dizzy could have a shitty coil.
Old Jan 29, 2012 | 12:28 PM
Ruy's Avatar
Ruy
Ill check to make sure Thanks the other thing is the gsr disturbiator that dont turn on my car no More turns on my friends b16 with no problem
Old Jan 29, 2012 | 12:35 PM
Dc4LsTeG's Avatar
EK9
So both dizzys work good on your friends car but not on yours?
Old Jan 29, 2012 | 12:43 PM
Ruy's Avatar
Ruy
Yes both worked on his only the b16 works on mine just that it makes my rpm neddle go crazy When i floor it and vtec hits
Old Jan 29, 2012 | 12:46 PM
Dc4LsTeG's Avatar
EK9
Sounds like its not the dizzy
Old Jan 29, 2012 | 12:51 PM
Ruy's Avatar
Ruy
Thats what i think i. Dont want to buy Another gsr disturbiator there expensive
Old Feb 4, 2012 | 04:42 PM
Ruy's Avatar
Ruy
Problem fix
Old Feb 5, 2012 | 03:09 AM
darksands's Avatar
Do you know anyone with a dizzy you can borrow? I had a similar issue where the car would run perfectly fine but the RPM's would jump around like crazy when I was on the gas. Borrowed a dizzy from a friend and it was fine so I just bought a dizzy on eBay and it works. I don't have vtec though.
Old Feb 5, 2012 | 03:18 AM
ennah's Avatar
What was the fix to your problem?
Old Feb 14, 2012 | 07:12 PM
Ruy's Avatar
Ruy
The coil
titi_vtec
Transmission & Drivetrain
Feb 6, 2011 01:18 PM
egmatt93
52
Apr 1, 2008 07:26 AM
