running error codes?
Old Oct 9, 2002 | 04:43 AM
Carp's Avatar
New User
Default running error codes?
how do I run the error codes on an 88 crx?
thanks
Ive done them on a 5g civic, I just dont know if its the same, or where the plug is to jump?ok I just figured it out, I have a single fast flash with about 2 seconds inbetween each flash. is that the 02 sensor?
thanks
[Modified by Carp, 3:07 PM 10/9/2002]
Old Oct 9, 2002 | 06:21 AM
EP3_05's Avatar
Default Re: running error codes? (Carp)
Sounds like the O2 sensor to me. You are probably going to need to replace it.
Old Oct 9, 2002 | 08:20 AM
311's Avatar
311
Default Re: running error codes? (91civic)
yes, code 1 is o2 sensor.
Old Oct 10, 2002 | 04:30 AM
Carp's Avatar
New User
Default Re: running error codes? (311)
I unpluged the O2 sensor, and I still get the same code, and no check engine light comes on. is this normal
Old Oct 10, 2002 | 04:36 AM
Stupid Ass's Avatar
Are you getting performance problems out of this or what? Or do you just not want the code to flash... cuz, if everything seems to be running fine I would just leave it be.
Old Oct 10, 2002 | 07:08 AM
REDBARON's Avatar
Default Re: running error codes? (SOHC NoTEC)
Well the CEL does not have to stay on for it to still be a problem. First reset your ecu, then check to see if the code comes back. If so, then you need to replace the O2.
Old Oct 10, 2002 | 08:14 AM
Carp's Avatar
New User
it is hesitating like crazy also my car is running very rich, but that could be from the 12:1 FMU
raphael
Aug 8, 2006 05:44 PM
JDM_EH2
Oct 20, 2005 11:49 AM
EFin' Kyle
14
Nov 11, 2004 08:37 AM
RJL
Nov 25, 2001 04:36 PM
