Weird revving
So my ex got bought a 96 honda accord doch vtec, it was running just fine until she had a friend look at the motor and realized that there were BMW spark plugs or some eurp. brand car and now it revs funny and i cant figure out what the problem is. It has honda plugs in it now. Any ideas?
Here ill help you out in case you don't know how to
https://honda-tech.com/forums/honda-accord-1990-2002-2/cleaning-iacv-fitv-tb-1844067/
Hello there, I had a similar issue with what I would describe as a surging idle.
In my case I found the problem to be a leaking intake manifold gasket.
The additional air being drawn into the engine was responsible for the surge in rpm.
My symptoms were much like what you described.
If you check your iacv and tb and still have issues, take a spray bottle with water and mist around areas you suspect a vacuum leak.
You should only concern yourself with areas downstream of the throttle body.
By misting these areas you can locate vacuum leaks by listening for a drop in idle RPM when you spray the leaking area.
Realize I am not talking about lots of water here, just a light mist.
Hope this helps, good luck.
Cal117
Jan 3, 2019 03:05 PM
mjacbos
Jul 12, 2007 06:10 PM
atlprelude01
Jun 23, 2003 02:26 PM
