How to clean out head bolt threads on block?
Old Jan 28, 2012 | 02:23 PM
hYbRid_Eg6's Avatar
Default How to clean out head bolt threads on block?
Now the block is almost put together, I chased the threads on the head bolts and used a tap to clean off threads on block, now do I take a bottle of brake cleaner and spray the holes with it while the block is upside down, then use air for the rest to get all the junk out?
Old Jan 29, 2012 | 11:54 AM
ej1 rep's Avatar
Default Re: How to clean out head bolt threads on block?
yup exactly what you said, air is a must to get all the **** out of there.
Old Jan 29, 2012 | 11:55 AM
ej1 rep's Avatar
make sure to put some assembaly lube on the head bolts when you put them back in. I just dipped mine in some clean motor oil.
Old Jan 29, 2012 | 07:51 PM
hYbRid_Eg6's Avatar
Cool thanks!
Old Jan 30, 2012 | 03:00 AM
cibao2ner's Avatar
i take an old headbolt and cut 2 slits with a dremel from top to bottom of treads and the dirt gets stuck in the slits when u spin it..
willard steen
Apr 5, 2016 12:22 AM
drumbum87
Apr 21, 2007 09:18 AM
servion
Jul 10, 2003 02:57 PM
Sonny
Nov 25, 2002 08:30 AM
275Performance
Feb 1, 2002 09:13 AM
