Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2005 TL car won't start.
Old Jan 28, 2012 | 12:19 PM
debo1's Avatar
Default 2005 TL car won't start.
Hi everyone,
I don't know much about cars and am in need of help! My TL is having start-up issues which led me to believe my battery was bad. I replaced my battery with a brand new one and 2 weeks later, I am still having issues getting the car started. I just had someone boost my car this morning, after a week of not running it, and it turned on. After letting the car run for about 30-45 minutes, I turned it off and the car is completely dead. Not a spec of power. What could be wrong? I really don't want to be ripped off by a local mechanic / dealership. Please help!
Old Jan 29, 2012 | 05:39 AM
alphalanos's Avatar
Default Re: 2005 TL car won't start.
get you alternator tested. also look at the battery cables to see if they are corroded.
Old Jan 29, 2012 | 06:52 AM
debo1's Avatar
Okay, i'll try that today. I am also trying to find what altenator would I for my car? I am sure there is a specific type, if I need to replace it.
Old Jan 30, 2012 | 12:11 PM
joelmatt89's Avatar
sounds like the alternator is the problem, although like others said it could be corroded wires or a bad ground. As far as the alternator goes... that is a specific part you will need, you could either get that from autozone, online or from a dealer. I would get one from rockauto.com (denso part no. 2100580) it is 160 minus 30 for a core. However judging by your posts it doesn't seem like you have done much work on cars in the past you should probably get a friend to help you replace this. I would rate this job considerably harder than a brake job. Simply because it is in a hard to reach location and requires you to take off the serpentine belt. For $30 you may want to replace the belt while your at it.
eazy64
15
Nov 11, 2010 08:53 PM
Cole89ef
Mar 6, 2009 03:40 AM
92civic_hatch
Feb 6, 2009 06:02 PM
hondacharged
Oct 17, 2008 02:02 PM
lawlerlaw
Jan 8, 2005 02:12 AM
