no power to map sensor
Old Jan 28, 2012 | 05:13 AM
egcoupe_900's Avatar
Default no power to map sensor
i have a 1993 honda civic d16z6 and i have absolutley no power to my map sensor......any ideas as to what could be causing this? need info asap car runs like ****.
Old Jan 28, 2012 | 05:17 AM
element600rr's Avatar
Default Re: no power to map sensor
need to get a pinout for the ecu check for power from there .. if there is power coming from the ecu then its a wiring issue if not prolly gonna be internal in the ecu .. more than likely its a wire issue .. im sure someone here has a link to a pinout for you ..
Old Jan 28, 2012 | 05:21 AM
Former User's Avatar
More information is needed. Is there a MAP sensor code? What wire are you testing for voltage and how are you doing the test?
Old Jan 28, 2012 | 06:13 AM
Jimster480's Avatar
How are you testing it? If you are sure there is no MAP sensor power when the car is in ON(II) then trace the wire back, it is either shorted or broken. I had the same problem happen to my Map except it was on the Ground. So I ran a new ground wire for it and its been fine ever since.
Old Jan 28, 2012 | 06:35 AM
no power to the map would cause low rpm sputtering? running rich? and really bad gas mileage correct?
Old Jan 28, 2012 | 06:39 AM
Jimster480's Avatar
yes
Old Jan 28, 2012 | 06:47 AM
Old Feb 3, 2012 | 12:32 PM
ok so heres a new scenario ive never seen before.....when i take the fuse out for the ecu and put it back in start the car and drive it it runs perfect....but next start up it runs like **** again???? replaced ecu and still same thing happens......any ideas?
Old Feb 3, 2012 | 12:38 PM
How can anyone help you if you refuse to answer any questions? Please stop posting until you are ready to reply point-by-point to questions.
Old Feb 3, 2012 | 12:44 PM
well wouldnt my last post state the fact that i figured the ****ing thing out? but im confused as to why it is doing that......hmmm id say that its more then just a map sensor problem...wouldnt you?
Old Feb 3, 2012 | 12:50 PM
No. Almost nothing important can be inferred or concluded from your information-less posts.
carlos8
36
May 4, 2014 05:42 AM
98greencrv
Honda CR-V & Element
Feb 24, 2014 04:30 PM
Charlie Moua
Apr 18, 2012 07:56 PM
JDM97R
Nov 11, 2004 01:28 PM
sleepin91teg
Aug 5, 2004 04:39 AM
