1995 Accord fog lights oem or aftermarket?
1995 Accord fog lights oem or aftermarket? I am wondering how good the oem style fog lights work. What kind of beam pattern do they have?
http://www.ebay.com/itm/94-95-HONDA-...item46007a45b1
OR
Should I install aftermarket generic fog lights?
OR
honestly bro get some good quality aftermarker ones and some hids put on it.. i would get clear housing with a yellow hid bulb.. or you could check craigslist for a pair...
The link you gave are the Generic OEM fogs. The real one will say Stanley on the fog housing. The light output the Stanley fog gives has a nice cut off. Thats what my JDM Yellow Stanley fogs does.
OEM-style fogs have absolutely terrible wiring harnesses - I'm probably one of the only members who's owned like 5+ pairs of foglights (oem and non) and I believe purchased the last BNIB OEM set from eBay (Majestic Honda) after a bidding war with a HondaSociety member.
Some differences:
- beam pattern on OEM is better (wider)
- light output on OEM is better (brighter)
- quality on OEM is better (harness, relay, switch, etc)
- colored light on OEM is different (blue/green vs the orange/yellow)
- OEM switch lights up, DEPO/OEM Style does not
- OEM fogs only come on with low beams (parking and high beams they are off)
- OEM-style stay on regardless of what lights are on (but they must be turned on)
- OEM harness is run via the front and passenger side and through a grommet at the bottom of the firewall near where the ECU is (plugs into base of fuse box)
- OEM-style runs across the front and driver's side and you push it through the door harness grommet near fender and bring it in by the interior fuse box.
- OEM-style rusted up the brackets and screws when I had them
- OEM rusted up the fog cover screws
I installed 3000K hid's in my OEM and had a pretty good cutoff, did not try it in the oem-style. I also installed some yellow Lamin-X over the lense to get the JDM look to them.
If you have any questions PM me.
Some differences:
Thanks muffin man.
I,m probably doing an oem switch. But I want to do hella fogs.
http://www.amazon.com/Hella-Optilux-.../dp/B000HVX34W
I feel that stanley lights will be a huge let down if I don't like them. If I don't like the hella fogs I can sell them. It will just take more time to install them.
No the brackets are not present on the vehicles. 96/97 you have to cut the grill, 94/95 I'm not sure but it doesn't appear you do - they sit above the center horizontal piece and not in it.
Krucial_Ek9
Jul 10, 2006 10:33 PM
