so basically...
Old Jan 27, 2012 | 02:09 PM
christmastree's Avatar
Default so basically...
if you are getting rid of your pcv system then you have to run a catch can? is this correct or am i mistaken?
Old Jan 27, 2012 | 02:25 PM
welfarepc's Avatar
Default Re: so basically...
you are mistaken.
and clearly you have done little research on the purpose of a catch can, and why a PCV system is even on your vehicle to begin with.
Old Jan 27, 2012 | 02:57 PM
Originally Posted by welfarepc
you are mistaken.
no actually i have done quite a bit of research. that is where my question came from. Maybe i have misunderstood what i have read which is why i have asked a question. It makes me angry when people jump to the conclusion that somebody hasn't done their research and is just being lazy. I spend countless hours researching about honda motors just because i love cars and i love soaking up knowledge. Obviously i do not understand everything about them since i am currently only on my first build. However that is why i am part of honda-tech. I feel that many people have questions about something they simply don't understand and get ridiculed on here. This is a forum and the entire purpose is to have a community that supports each other In their Honda endeavors. I am not trying to call you out and i am not trying to fight on my thread. I just want to make it clear that i never ask a question without trying to figure it out on my own first. Anyway here is my understanding of it.... You have to get rid of the pressure in your block somehow. however, due to emissions they came up with the pcv which rerouted it back into your intake. So whenever you get rid of the pcv system you have to make another way to release the pressure. Which is why from what i understand you use a catch can because it is going to release the presure from your block and catch the blow by. As i asked originally.... is this correct? do i have to run a catch can if i am eliminating the pcv?
Old Jan 27, 2012 | 03:03 PM
93egSLEEPER's Avatar
Just use a vented breather filter on the PCV nub on the back of your valve cover. I use a wire mesh screen mini filter on mine. It is sufficient enough unless you are making pretty big horsepower where blow-by is in abundance.
Old Jan 27, 2012 | 03:26 PM
well see that was my original thought.... however i was told here https://honda-tech.com/forums/all-motor-naturally-aspirated-44/can-i-plug-these-3020930/ that a breather on the valve cover was insufficient
Old Jan 27, 2012 | 03:46 PM
00Red_SiR's Avatar
All Motor Mentor
Originally Posted by christmastree
well see that was my original thought.... however i was told here https://honda-tech.com/forums/showthread.php?t=3020930 that a breather on the valve cover was insufficient
He's probably also using a breather box. I use a breather box and a small filter on the valve cover nub. Are you just wanting to clean things up or is there another reason why you don't want to run the stock system?
Old Jan 27, 2012 | 03:58 PM
you nailed it right on the head. i am wanting to clean things up and keep them as simple as possible. i am planning to get rid of any and all unnecessary sensors, emissions, and anything that is just unneeded. this is going to be used for auto cross and only as a toy to drive around. i want it to be as simple as possible under the hood. it will look nice and make it much easier to work on
Old Jan 27, 2012 | 04:03 PM
00Red_SiR's Avatar
All Motor Mentor
If that's the case, I would honestly keep the stock PCV box and valve since it sits tight behind the engine and is hardly noticeable. The filter on the valvecover nub will clean things up and prevent your TB and manifold from getting as dirty but allow your engine to properly ventilate when you compete during an autocross.
Old Jan 27, 2012 | 04:04 PM
also i am running itbs...
Old Jan 27, 2012 | 04:35 PM
on-site's Avatar
I had the same question I'm also going to run itbs but will not be running crazy horsepower I do have a breather set up and was thinking if I should make the two holes on the valve cover
Old Jan 27, 2012 | 06:52 PM
00Red_SiR's Avatar
All Motor Mentor
I believe ventilating is important so the engine should not be sealed with just a filter on the valve cover so a small subtle catch can setup that connects to the back of the block and maybe the back of the valve cover might be best. I would see what other guys do when running ITB's.
Old Jan 27, 2012 | 07:24 PM
well i have an idea for an easy one. ill post pics in my build thread once i get it together
Will Gardner
Honda Civic (2006 - 2015)
Oct 24, 2015 05:24 PM
carksi08
Aug 22, 2008 03:05 AM
themorphious
Jul 10, 2006 09:37 AM
adictionbass
Jan 18, 2005 04:28 PM
