hesitation, vtec malf code1259
Old Jan 27, 2012 | 12:34 PM
dwr1977's Avatar
Default hesitation, vtec malf code1259
Just serviced the head on my 2000 accord with the ulev vtec head and now have a hesitation in the engine while it climbs through rpms then revs smooth above 3000 rpms, check engine light comes on with P1259 vtec system bank 1 malfunction trouble code. I have tested and cleaned the lock up solenoid, continuity in spec.
Any ideas were to go next?
Thanks
Old Jan 27, 2012 | 05:01 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: hesitation, vtec malf code1259
Have you cleared the code to see if it comes back?
Old Jan 28, 2012 | 07:04 AM
dwr1977's Avatar
Yes, I have cleared th code and it comes back. I think the solenoid valve assembly may be not functioning properly, wen i cleand it there were several fine scratches at the bottom of the plunger. The plunger does move easily but had more resistance in the mid point of its travel, im thinking that maybe is has some binding going on that may be the cause.
dwr1977
Mar 2, 2012 02:34 PM
GibsonNO!
Feb 27, 2009 06:05 PM
Pr0ject93hb
Sep 14, 2007 09:50 AM
ganjasnack
Jun 11, 2007 02:38 PM
Ala_2DrAccord
May 12, 2004 04:22 PM
