94 civic horible carbon spark foul after 5 mins
Old Jan 27, 2012 | 11:07 AM
Billitary's Avatar
Default 94 civic horible carbon spark foul after 5 mins
Hi I have a 94 honda civic with a d15b7 it runs for about 5 mins then my spark plugs are so carboned they cant start. I cant figure it out no check engine light new distributor wires cap rotor ecu spark plugs, o2 sensor. I cleaned the intake ivac throttle. Changed out the injectors with junk yard ones. Rebuilt motor new crank, bearings rings. Used block, head wit 80k on it, and pistons and conmecting rodsi am about to blow my brains out because of it lol
Old Jan 28, 2012 | 09:16 AM
Billitary's Avatar
Default Re: 94 civic horible carbon spark foul after 5 mins
Bump for help
Old Jan 28, 2012 | 09:20 AM
grumblemarc's Avatar
The Grumpiest
Too much fuel? Smoking? TIming?
Old Jan 30, 2012 | 01:36 AM
Billitary's Avatar
It was because the canister purge vauvl.
Old Feb 16, 2012 | 11:23 PM
rickyi869528's Avatar
Was it bad, or one of your lines disconnected? I ask because I just found the vacuum line that goes from the throttle body to the purge valve disconnected, and wondering if that's why it sometimes doesn't want to start.
Old Feb 16, 2012 | 11:46 PM
FkenMustangs's Avatar
Could be, if it doesn't have enough vacuum it wont want to idle. Does it act like it wants to start and fall off?
levi4396
May 21, 2017 08:55 AM
masuhiro
Dec 30, 2014 01:19 PM
Hondaguy83
Dec 5, 2012 05:21 PM
skazoo
Oct 11, 2007 02:39 PM
gillyfesh
Sep 16, 2005 10:34 AM
