Injectors or fuel pump?
Old Oct 9, 2002 | 12:33 AM
spcmotorsports's Avatar
Default Injectors or fuel pump?
if i wanna give my b16a more fuel should i got fuel pump or injector?
Old Oct 9, 2002 | 05:24 AM
Bontke's Avatar
Default Re: Injectors or fuel pump? (spcmotorsports)
Larger injectors will increase fuel, but they will require tuning (cipped ECU) to keep the A/F levels correct. Usually a larger injector will give you too much fuel.
A larger fuel pump will flow more fuel and could overpower the regulator thus giving you more fuel, but you will never know exactly how much extra fuel you wil get.
An adjstable fuel pressure regulator would be ideal. You could control the extra fuel to the injectors making them run rich.... adjusting the pressure will control the ammount of extra fuel pressure the injectors see. This gives you somewhat an ability to tune the car.
LS/V-T
Nov 30, 2010 02:09 PM
existanzcivicb20
Apr 20, 2006 09:23 PM
big juan
Oct 29, 2005 06:59 AM
baonest1
Apr 21, 2003 09:05 AM
Tripz
May 6, 2002 06:04 PM
