D16a1 Blacktop boosted?
Old Jan 27, 2012 | 09:02 AM
88G1teg's Avatar
Default D16a1 Blacktop boosted?
so i have an 88 integra ls, recently the head gasket went up so i replaced the head gasket (OEM), Valve seals(supertech), Head Bolts (OEM), Water pump(OEM), Timing Belt & Tensioner(OEM), and all gaskets from the head up.
ive been looking into turbos alot, im in the process of building an lsv with forged internals, but before the swap i want to slap an ebay turbo kit on there cuz the motor im building wont be done for a little bit.
i already have a tial 38mm wastegate
greddy type rz bov
aem wide band & boost gauge.
going to get the rest of what i need off ebay, like fmic, manifold, turbo, some dsm injectors, and oil line(name brand). also going to get hondata s300 from a friend soon.
what i want to know is there anything else i should get?
and how much hp can my stock motor w/ stock internals handle safely?
i know a ls can handle 300+ stock but what abuot a d16a1 blacktop
cr is 9.6:1 ( incase you dont know the difference between the black &brown top)
thanks in advance, looking forward to my first turbo build
Old Jan 27, 2012 | 10:42 AM
88G1teg's Avatar
Default Re: D16a1 Blacktop boosted?
no one?
Old Jan 27, 2012 | 11:04 AM
Blove1991's Avatar
I would recommend getting a turbo from a more reliable source. What is your power goals? That is the main thing. Having the money for a reputable tune at the end of the build is also very important.
Old Jan 27, 2012 | 09:22 PM
95civhb's Avatar
If you are going turbo with your LSV, why not buy a quality setup and run that on the d16? Sure, it'd be laggy (depending on the turbo and setup), but your higher compression ratio with the d will help... then you just have to change injectors/manifold..
Old Jan 29, 2012 | 03:35 AM
88G1teg's Avatar
as the other guy said, insted of rushing to het a cheap turbo on there im going to wait and peice togeather a a nice turbo kit with a cheap log manifold for now...
as for power goals, its whatever i can safely push out of this motor stock.
thats what im trying to findout.....
also my car is going to be tuned by Mike Sweeney @ CCT
Old Jan 29, 2012 | 06:36 AM
blackeg's Avatar
i have a friend who used to run a boosted a1 honestly 10 years ago. i think it was around 300hp and going 12s at the track. i know he used to be on here but that was many years ago.
Sickcpe
Honda Civic (2001 - 2005)
Dec 22, 2016 02:02 PM
boarding2008
May 24, 2013 04:19 AM
ls_on_boost
May 9, 2009 05:44 AM
xXx Justin xXx
Feb 9, 2003 05:31 PM
