dual carbs on ZC
yes, but i forget who makes it... cannon? i remember katman was selling the manifold, mikuni carbs, and throttle linkage... that was a while ago though.
I found a dual carb set up for the 1st gen teg at nopi
http://www.nopionline.com/index.cfm?...rburetor%20Kit
Carbs on a ZC bark like crazy! make descent power but you need the compression and head work to really make it...price seems a little steep see if you can just find a manifold for the motor then get a descent used set of carbs somewhere else also myte want to check out TWM also.....S13 slide huh, you drift'n outside of the EF?
