88 Crx High Idle; Doesn't start!
Old Jan 26, 2012 | 06:52 PM
srok1's Avatar
Default 88 Crx High Idle; Doesn't start!
I recently bought a 88 crx [base model] to slowly restore and the motor seemed to be in good condition (140k).
Anyways, I went to a drive-thru right after getting off the freeway and my car stayed idling a little bit high at around 1500k-2k. I turned off my car in the drive thru and tried turning it on, but it wouldn't ****ing turn over. I was so embarrassed but finally I get back in my car from checking the engine and it started again. This all happened in a span of 2 minutes approx.
I'm prepared to work on the car this weekend; any advice as to where I should be looking? I don't have any fluctuating idle or anything like that so I could count the radiator out. I'm not sure exactly where to look at with this motor.
Old Jan 26, 2012 | 08:54 PM
89 LX SOHC ZC's Avatar
Default Re: 88 Crx High Idle; Doesn't start!
Sounds like the main fuel injetion relay ive had this problem and it was the relay.
Old Jan 26, 2012 | 10:27 PM
still's Avatar
sux
Old Jan 26, 2012 | 11:17 PM
srok1's Avatar
So is it just the fuse? Box looking thing like this:
Old Jan 27, 2012 | 06:21 AM
crvtectim's Avatar
Check for any blown fuses. Check for fuel and spark. If it's getting neither, then try swapping in a good main relay.
Old Jan 27, 2012 | 06:15 PM
Thats the one.
Old Jan 27, 2012 | 07:10 PM
srok1's Avatar
Thats the one.
Okay, I'm going to check it tomorrow morning.
Old Jan 28, 2012 | 04:47 PM
Jhicks's Avatar
mine was doing that and i just readjusted the idle and the tps.
Old Feb 23, 2012 | 07:47 PM
srok1's Avatar
Damn, okay guys so I replaced the battery, spark plugs, spark plug wires, main FUEL INJECTION RELAY aaaand the valve cover gasket with grommets (spark plugs had oil on them). It drives better (obviously) but the idle problem is still there. It fluctuates from 1k to 2k now and sometimes it just stays at 2k for a long time and sometimes if i just rev the motor it goes back to normal and sometimes it goes right back to high idle.
The motor hasn't died on me YET, but I was wondering what other steps I should be eliminating now to get closer to fixing it.
Old Feb 23, 2012 | 08:33 PM
srok1's Avatar
Heres a video to better see, you dont need to watch the entire thing really.
http://s2.photobucket.com/albums/y7/...223_194630.mp4
Oh so during the first few moments I had revved it and it went back to normal; than turned it off, turned it back on. And it went to high idle and revved it and it went to fluctuating.
Old Feb 24, 2012 | 05:16 AM
crvtectim's Avatar
You need to clean the FITV. Search it.
Old Feb 24, 2012 | 06:33 PM
srok1's Avatar
Yeah, I have no idea where the FITV is; I've Google'd and read a ton of How-To for it but they are for engines other than mine [D15b non vtec PGMFI]. I'm confused as to where it is. I've found the IACV though which I will be cleaning as well....
XspeedSi02
Mar 3, 2008 09:51 PM
djsire
22
Oct 8, 2005 05:06 PM
thatruhotsauce
Jun 17, 2005 11:21 AM
hondacru27
Jan 26, 2004 10:48 AM
infinityminus1
13
Dec 21, 2001 01:18 PM
