spoon mirror wiring help
Old Jan 26, 2012 | 02:46 PM
toolow69's Avatar
Default spoon mirror wiring help
hay whats up. i just got some spoon "style" mirrors for my 93 coupe. i need help with the wiring. it has 3 wires. green,yellow, white. the wires on the plug coming out the door are different colors. does anyboby know or have done this before help me out!!!!! what colors go to what??? please help. i searched and came up with nothing. dont tell me to play around with the wires. this has been done before, just want the correct way. thanks in advance!!!!
Old Jan 26, 2012 | 02:54 PM
Wrona's Avatar
Default Re: spoon mirror wiring help
why not contact the place u got them from
Old Jan 26, 2012 | 03:17 PM
grumblemarc's Avatar
The Grumpiest
https://www.google.com/search?q=spoo...ient=firefox-a
Old Jan 26, 2012 | 05:18 PM
toolow69's Avatar
there ebay knock offs, so no instructions were included. i googled but found nothing. lots of the same questions asked but no answers. i found out for the 4 wires but nothing for the 3, which i have. anyone????
Old Jan 26, 2012 | 05:24 PM
The Grumpiest
Hm. Found this in about 10 seconds.
"1 wire is probably earth.
1 is for up/down
1 for left/right.
reverse polarity to go other way......... "
I'm sure you aren't applying yourself.
Old Jan 26, 2012 | 05:26 PM
The Grumpiest
Or this one in another 10 seconds of searching.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-wire-spoooon-powered-mirrors-96-00-civic-2194064/
With pictures.
And if you're looking for a DIY for a set that has the EXACT same wire colors you're probably going to be SOL.
Old Jan 27, 2012 | 11:32 AM
toolow69's Avatar
thanks for no help!!! i found out were each wire goes after hours of searching and tril and error.
driver side: yellow/white= white
blue/ black= green
blue/ white= yellow
pass side: yellow/white= white
yellow/ black= green
yellow/red= yellow
everything works as it should. this is for 92-95 civic
Old Jan 27, 2012 | 11:46 AM
The Grumpiest
Helped as best I could. You bought a set of no-two-manufacturer-alike crap "Spoon" mirrors off of some drop shipper on Ebay WITH NO INSTRUCTIONS and you expected someone to know which kind YOU bought that matched the SAME color wiring? There were only 3 wires and it took you hours?
Old Jan 27, 2012 | 12:11 PM
The Grumpiest
Next time get a wiring diagram for your car and a meter.
Old Aug 14, 2012 | 05:19 AM
bautistapedro's Avatar
blue/ black= green
blue/ white= yellow
yellow/red= yellow
For some reason, my spoon style mirrors from ebay have four wires; two blue, white, brown, & black. I didn't order these off ebay, I baught them off a friend. Idk how to wire them at all
Old Aug 14, 2012 | 05:23 AM
blue/ black= green
blue/ white= yellow
yellow/red= yellow
I meant ONE blue wire, one white, one brown, & one black. But my oem harness is, two blues, one with a white stripe, one with black. & a yellow cable with a white stripe. 94 honda civic coupe ex
Old Dec 14, 2013 | 05:16 PM
Oscar91's Avatar
blue/ black= green
blue/ white= yellow
yellow/red= yellow
Do u have pictures??..I have the wires connected I just don't know how to hide them...also,are u using the wires that connect to the oem mirrors?the ones that go down to your door panel!
Rishiras
Jan 20, 2011 04:30 PM
CubbyChowder
Jul 21, 2010 06:36 PM
ase2
Oct 26, 2008 09:10 PM
qwrty
Aug 14, 2008 07:24 AM
