94 Sol Vtec radiator fan not working
Old Jan 25, 2012 | 11:40 PM
OmgDelSol's Avatar
Default 94 Sol Vtec radiator fan not working
I've checked my radiator fuse and it was good so i'm guessing its the actual fan? Is there any common issue of why it stopped working? Also could anyone suggest a good radiator fan? Since i'm going to buy a new one i might as well buy the best there is.
Old Jan 26, 2012 | 01:37 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 94 Sol Vtec radiator fan not working
Have you tried jumping the radiator fan switch on the thermostat housing? Its the round plug, take a paperclip and connect the two terminals with the car on and see if the fan cuts on. If it doesn't you probably have a bad motor. If it cuts on when you do this you have a bad fan switch.
Old Jan 26, 2012 | 05:57 AM
Red_Army's Avatar
that first^
FAL would be my top choice.
is this just a stock car that you DD?
because in that case a cheap OEM one would be best.
Old Jan 26, 2012 | 07:16 AM
MonkeyBoy668's Avatar
The only way to know for sure if the motor is dead is to run some leads from the battery to the fan. If it works then you know it's either the switch (easily tested by the above method), a broken wire in the harness, or a short (which will blow a fuse, but depending on where the short is it may only blow when the fan switches on).
Old Jan 26, 2012 | 08:58 AM
OmgDelSol's Avatar
ok so I unplug the wire running from the fan? I've jumped an AC unit before but I can't remember. Sorry.
This car is my daily but I plan on building my engine this summer so if itd be better for me to buya higher performance fan then now is the time to do it right?
Old Jan 26, 2012 | 11:47 PM
thisdamnhonda's Avatar
im having the same problem but i no the radiator fans good and i just bought a new radiator fan switch but it doesnt come on as its supposed to only when i notice it climbing when im at a stop light and i have to turn on the defrost for the fan to come on idk if i just bought a bad switch or not
Old Jan 27, 2012 | 01:34 AM
Technical Hero
https://honda-tech.com/forums/honda-accord-1990-2002-2/diy-c-cooling-system-2793650/
This is for an Accord but its pretty similar (except the relay is in the fuse box for the fan) and the Civic has only one fan switch but testing is the same.
Civicmick
Aug 14, 2015 07:27 AM
EGed up from the seat up
18
Jun 1, 2011 02:16 AM
Corksil
Dec 9, 2009 06:56 PM
dragaholic
Jul 29, 2006 11:43 PM
BHNTech
Apr 29, 2006 07:39 PM
