RPM Problems after Alternator swap
Old Jan 25, 2012 | 11:02 PM
Jdm_JavieR's Avatar
Default RPM Problems after Alternator swap
So my car died from a bad alternator about a week ago and today i finally replaced it.
But Ive noticed the car is not running "normal"
First I had a few blown Fuses that had to be replaced also the Headlight went out as well
But the real problem imo is that The RPM needle is stuck at zero and will not respond to throttle inputs. But ive noticed that it works Perfectly fine
when the doors are Open?
What could be causing this ?
Also, after installing the Alternator the Battery warning light has Not Shut off.
Is this normal?
Old Jan 25, 2012 | 11:45 PM
Solster's Avatar
Default Re: RPM Problems after Alternator swap
Sounds like a Bad ground.
and the battery light should go off when the alt. is working.
so you eather got a BAD alt or you didn't get it installed correctly
Recheck all the connections at the alt. and all your grounds.
Old Jan 25, 2012 | 11:46 PM
Solster's Avatar
also What is the car Year make model and what engine?
Old Jan 25, 2012 | 11:51 PM
Jdm_JavieR's Avatar
94 LS with a b18b1
Old Jan 26, 2012 | 01:16 AM
Solster's Avatar
ok so it stock and did the tach work befor the alt died?
if yes i'm sticking with bad grounding
also did you check all the fuses both under the dash and under the hood ones?
cjwang2
Mar 26, 2015 08:51 PM
76 camaro car
Mar 13, 2012 04:04 PM
CivicSD
Oct 25, 2010 09:24 AM
TigerLy
Apr 1, 2009 04:08 PM
rasta420
Oct 2, 2006 04:46 PM
