H23a1 in a 96 ex pleazzze hhhhelppp
Old Jan 25, 2012 | 08:48 PM
previc 96's Avatar
Default H23a1 in a 96 ex pleazzze hhhhelppp
I got a 96 h23a1prelude engine in my 96 civic ek and I really need help with getting it running ryte I need some good advice on wat ecu to get or if I am able to get my ecu chipped I will do that but I have yet to find a program that will work for it any advice anybody?all help is much apreciated also is there any way to bypass the idle air control valve if I get the ecu chipped cause I have a no name after market intake mani on it that dont even have the idle air control valve on it or anywhere to put one so the idle flucuates.it goes up an down fromm 1000 to 1500
Old Jan 25, 2012 | 08:52 PM
Dc4LsTeG's Avatar
EK9
Default Re: H23a1 in a 96 ex pleazzze hhhhelppp
Put this in the civic section
Old Jan 25, 2012 | 08:57 PM
previc 96's Avatar
Im new to this I just need help thought I might find it here on honda tech ..but y put it in the civic section it has a h23a1 u think I would get more answers there or?
Old Jan 25, 2012 | 08:58 PM
Dc4LsTeG's Avatar
EK9
Yes that's why I said it
Old Jan 25, 2012 | 09:05 PM
previc 96's Avatar
Thanx for the advice how do I do that do I have to write a new one or is there a way to move wat is already written
Old Jan 25, 2012 | 09:23 PM
Dc4LsTeG's Avatar
EK9
Pm a moderator and have them move it. Don't make a new thread. Sorry I'd help but I know nothing about h swaps
Old Jan 26, 2012 | 05:32 AM
Apex1972's Avatar
OMG not the skunk2 ripoff manifold. thats the worst quality piece of garbage I have ever seen . just go drive your car off a cliff please.
Old Jan 26, 2012 | 05:38 AM
previc 96's Avatar
Alright thanx muac appreciated I will message a moderator who is that an how do I do it tho? Sorry im still trying to learn how to fully use the site
Old Jan 26, 2012 | 08:37 AM
elemntsk8r16's Avatar
p14 ecu is the ecu that came with the 96 prelude Si h23a1. I would reccomend getting one of those. you can do a chipped and tuned ecu as long as it has the correct base maps. i reccomend the p14 though and you wont have any problems. chip and tune it yourself later on
Old Jan 26, 2012 | 12:25 PM
BergRacing21's Avatar
lol harsh, but funny.
that idle problem is due to the fact you have no IACV. I doubt you can tune to take that away? but maybe i'm wrong.
Old Jan 26, 2012 | 12:46 PM
previc 96's Avatar
Alright thanx ill get the p14 bak in it and ill go buy a stok intake to put on so I can get the iacv hooked up and hopefully itll work but I have another question if the ecu I am currently running has a rev limiter and the two step launch control its already chipped huh? And to apexi I kno its not the skunk 2 u have anyidea wat it might be ? Im jus goimg to take it off ..
Old Jan 26, 2012 | 12:53 PM
previc 96's Avatar
Should I jus put my h22a4 dohc vtec in it ? I dont like the h22 but if it will be easier ill jus go with that cause I have the stok intake for that or will that intake work on my h23
Old Jan 26, 2012 | 01:20 PM
as far as i know the H22 intake manifold will work for it. lol why do you not like the H22? just curious. Well if your rev limiter is higher or lower than the stock settings than yeah...but if it has a 2-step it's more and likely already chipped, which could be another problem in itself cause that ECU could be tuned for another cars' liking.
Old Jan 26, 2012 | 09:16 PM
Yeah why go h23 when you have a h22?? I mean yea a h23 has slightly higher displacement and torque but h22 has the better top end all day and all the benefits of vtec. Anywho, if that's what u wanna do that's cool. Sounds like you have the wrong base maps on your ecu. Since it seems to be chipped already you can.probably pick up the maps u need online or have someone do it. I'm curious as to what ecu you are using currently tho. Any chance u could share this info?
Old Jan 27, 2012 | 04:48 PM
previc 96's Avatar
I jus didnt wanna go vtec cause I have a greddy boost kit that I was going to get put on when I got my car running ryte and I do like the h22 jus ive heard bad things bout boosting them and I figured id try to find a crx to throw the h22 in ...and thanx for the advice im gonna try out the h22 intake and i was running a pr4 but I jus put the p14 I had in . And now im bot to go to a local shop with a dyno and have them set the pr4 with the ryte base map since u said it could be the wrong one but im going to do that after I put the h22 intake on
Old Jan 27, 2012 | 04:53 PM
previc 96's Avatar
And thanx for the advice guys it is running jus a litte better with the p14 but not allot better but I think u have me on the ryte trak to getting it runnin ryte
Old Jan 28, 2012 | 07:11 AM
97ludedude's Avatar
*thanks, *just, *little, *alot, *you, *right, *track, *running, *right. Sorry that was getting on my nerves.
Old Jan 28, 2012 | 03:22 PM
previc 96's Avatar
Hahahahahaha sorry didnt kno we had spell checcs
turbodelsolb16a2
May 4, 2010 02:50 AM
endless1
May 31, 2006 05:29 PM
HondaCivicAddict
Jan 22, 2005 04:18 PM
Ichigo
Sep 21, 2004 08:18 AM
I AM GAY
Oct 6, 2002 08:06 PM
