Idle Revving
Old Jan 25, 2012 | 07:08 PM
JdmMidWest's Avatar
Icon2 Idle Revving
I once saw a civic that was slowly revving up and down while it was idle. A friend told me that a performance camshaft will do this. Anyone know what causes this?
Old Jan 25, 2012 | 07:09 PM
Dc4LsTeG's Avatar
EK9
Default Re: Idle Revving
lol..A cam won't do that. Usually the iacv causes it
Old Jan 25, 2012 | 07:20 PM
JdmMidWest's Avatar
Yea idk how he figured that but whats going on when this happens
Old Jan 25, 2012 | 07:22 PM
Dc4LsTeG's Avatar
EK9
The iacv is dirty usually. Search it and a bunch of threads will pop up. It's not something you want your car doing, if that's what your asking
Old Jan 25, 2012 | 07:30 PM
hondad6's Avatar
Yeah a car with a big cam sounds way different than a dirty IACV. you tube has a lot of videos of both.
Old Feb 9, 2012 | 08:38 PM
94blur's Avatar
Yea usually its a dirty iac valve. You can pull it out and clean with some brake clean/carb cleaner. Or just replace it.
This problem may also be caused by a vacuum leak. Leaking intake gasket. Be careful and make sure your ignition wires Arent arcing and spray brake clean around the intake a see if u notice a change in idle. If you do sense a change, theres your leak.
Hope that helps
HIallday
Sep 13, 2011 10:34 PM
obuhmyuh
Jul 10, 2008 03:45 PM
93SiPrelude
Feb 24, 2008 10:39 PM
chocolate moose
May 25, 2005 05:58 AM
94SHOWLS
Feb 17, 2005 12:31 PM
