What size door speakers come in a 98 civic ex?
Old Jan 25, 2012 | 06:13 PM
98EJ7Y8's Avatar
Default What size door speakers come in a 98 civic ex?
this may sound dumb but what size door speakers come in a ex
Old Jan 25, 2012 | 06:19 PM
grumblemarc's Avatar
The Grumpiest
Default Re: ? 98 civic
Don't remember off hand but if you're shopping for speakers go here.
http://www.crutchfield.com/S-J2Cn21vBqhJ/
Use it as a guide for fitment only.
Old Jan 25, 2012 | 06:21 PM
98EJ7Y8's Avatar
thanks use to get this mag in the mail a while ago and they have great product
Old Jan 25, 2012 | 06:24 PM
Former User's Avatar
Default Re: What size door speakers come in a 98 civic ex?
Please place simple technical questions directly into the thread title -- Title edited.
Old Jan 25, 2012 | 06:42 PM
motegicivic's Avatar
6 and 1/2 door, 6x9 rear deck.
Note the door is shallow depth, unless you cut the plastic cup.
Old Jan 25, 2012 | 08:30 PM
sde780's Avatar
"Regular" 6.5" speakers don't fit, I read you need the 5.25" ones. I know for sure that my Polk 6.5" components don't fit
Old Jan 25, 2012 | 10:10 PM
98civdx's Avatar
Master Detailer
My Infinty 6.5's fit nicely.
You need to trim the plastic cup out for almost any speaker to fit.
Old Jan 25, 2012 | 10:11 PM
hondamaster703's Avatar
6.5 should fit perfectly.
Old Jan 26, 2012 | 03:06 AM
jbpnoman's Avatar
JL XR and ZR series speakers will require some serious fabrication to make them fit, just FYI, but damn do they sound good.
Old Jan 26, 2012 | 03:53 AM
sde780's Avatar
I stand corrected, standard 6.5" do fit. However "oversize" 6.5" do not, which may be the case with my Polks and several other speakers out in the market. That is not to say 5.25" will not fit; the OEM baffle even has 4 holes to bolt it on.
I knew I read somewhere about 6.5" not fitting...it's the oversized ones that don't.
Old Jan 26, 2012 | 06:56 AM
Well some manufacturers, market speakers as 6.5/6.75 those are typically bigger.
Old Jan 26, 2012 | 09:32 AM
98civdx's Avatar
Master Detailer
This is true.
I had some old kicker ds650's, what a PITA.
The terminals were on the sides, No way of getting them to fit without chopping up the pannel.
But, 9 times out of 10, the baffle, or the "cup" will need to be removed, unless you're speakers are pretty shallow.
Are you sure that isn't that issue? The cup takes minutes to remove.
Masho
Honda Civic (2001 - 2005)
Jan 8, 2012 01:58 PM
HondaCrazy20
Audio / Security / Video
Sep 5, 2005 03:21 PM
Unjockable
12
Dec 15, 2003 10:22 AM
CivHizzle
Dec 10, 2003 03:38 PM
Loveless
Feb 20, 2003 09:38 AM
