guidence on adjustable cam gear settings...
Old Jan 25, 2012 | 03:51 PM
JDMAF's Avatar
Default guidence on adjustable cam gear settings...
Hey guys, wondering if I could get some guidence on settings on adjustable cam gears... I know the best way to do it is on a dyno but was wondering if anyone with a similer set-up could give some advise or if someone had a good way of doing it that would be fine to... heres the set-up.
92 cx hb
obd0 b16 converted to obd1
stock bottom good compression across all 4
head has GSR cams and was shaved .007 to true head
AEM cam gears (got them with the motor)
skunk 2 intake manifold
70mm omni tb
big tube tri y header
no cat
greddy exhaust
any help would be useful...
Thanks
Jeremy
Old Jan 25, 2012 | 04:47 PM
apexi_rsx's Avatar
Default Re: guidence on adjustable cam gear settings...
if u want to try advancing 1* u can. every .012 u shave u advance the cam 1*. so u would be a lil less then one degree.
akura404
Nov 21, 2006 10:26 PM
SonicRacing
May 22, 2006 11:06 AM
CANTFAZZDISCHIT
Apr 4, 2004 07:16 AM
gdout90accord
Mar 29, 2004 12:07 PM
blumeany
Jan 22, 2004 07:15 PM
