96 Civic - low idle and stutter problems
Old Jan 25, 2012 | 02:58 PM
theidoctor's Avatar
Default 96 Civic - low idle and stutter problems
so i have a 96 honda civic 5 speed.
i have 2 problems that i have started noticing.
1. started about 1 month ago. Simply when i stopped, the car would idle very very low and sometimes shut off. It would usually happen after it had warmed up a little, but it still does that at times.
2. started about 2 weeks ago. When i am driving, i feel the car stutter or "jolt" for a little bit... It usually happens right after i shift gears and then it will just go.
I checked fluids and the only thing that was low was coolant and last oil change was 4000 miles. Im not sure about the other maintenance stuff.
I dont know too much about cars so please try to keep it simple.
Old Jan 25, 2012 | 03:19 PM
hannslebo's Avatar
Default Re: What the heck is wrong with my car?
Lets start with the Check Engine Light? Is it on?
Old Jan 25, 2012 | 03:45 PM
Former User's Avatar
Default Re: 96 Civic - low idle and stutter problems
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old Jan 25, 2012 | 05:50 PM
509ernie's Avatar
Had the same problem wit mine ....i replaced the distributor and problem solved..
Old Jan 25, 2012 | 05:54 PM
grumblemarc's Avatar
The Grumpiest
If you've never done a tune up since you've owned the car you might want to try that first.
Old Jan 25, 2012 | 06:33 PM
theidoctor's Avatar
No check engine light.
Will look at distributor.... and tuneup.
Also, thanks for the title.
brandon dorsey
Apr 14, 2016 06:41 AM
skippysg
May 27, 2010 06:52 PM
Iloveyourhonda92
Apr 12, 2010 07:23 PM
ra64
Mar 8, 2007 11:52 AM
