Tire stretch safe?
Old Jan 25, 2012 | 10:55 AM
kriscabrera's Avatar
Default Tire stretch safe?
Hey guys am getting 16x8.25 and was wondering if its safe running a 205? i think standards are 215
Old Jan 25, 2012 | 06:01 PM
toyomatt84's Avatar
Sanji
Default Re: Tire stretch safe?
From the Forum Rules and FAQ:
10. Do not ask about "stretching" tires onto wheels that are too wide.
All such topics will be locked. Tire manufacturers determine the wheel widths onto which each model and size tire can be mounted safely, and you can find the range of these wheel widths in the specs on their websites as well as those of retailers like the Tire Rack. Mounting tires onto wheels outside this range of approved wheel widths is unsafe because it can, and often does, result in the buildup of excessive stress and heat in the tire sidewalls, which can lead to the tire "popping the bead" and/or tire failure. Make sure your tires are mounted on wheels whose widths are within the approved range.
This type of question is better suited for the Appearance forums, if anywhere.
Outlaw-Hondaz
Jun 21, 2011 10:25 AM
racerx510
Jun 5, 2011 05:48 AM
hoxsie323
Jun 1, 2011 04:30 PM
mrbkelley
May 22, 2011 07:08 PM
Stewie
Dec 4, 2003 07:34 PM
