How to fix rear window flex?
In an attempt of theft my rear window on my 2000 ek coupe is coming off from the backside, the adhesive is not strong anymore and barely holds the window on. What type of glue can I buy to fix this or do I need to take it somewhere to get this repaired?
Can you see gaps?
Typically you need to take it in, there is a molding that need to take off, not replaceable, remove the window, use urethane reset the window and molding etc.
