Suspension & Brakes Theory, alignment, spring rates....
pillowball type coilovers
Old Jan 25, 2012 | 09:46 AM
takumi_san's Avatar
Default pillowball type coilovers
does pillowball type coilovers really make a lot of noise?
My recently purchased eg hatchback came with an Aragosta coilovers. it makes a lot of noise when driving on a bad road. i had it checked, and i was told that pillowball kind of coilovers really makes a lot of noise. is this true?
thanks!
Old Jan 25, 2012 | 10:00 AM
phunhaus's Avatar
Default Re: pillowball type coilovers
They make more noise than standard bushing coilovers but if they're really really loud then the bearing might have to be replaced or at least serviced if possible.
Old Jan 25, 2012 | 11:52 AM
Kozy.'s Avatar
a.k.a. Komodo
Replace them with standard rubber if you can, they serve no discernable purpose on double wishbone cars other than to increase NVH.
Old Jan 25, 2012 | 11:49 PM
takumi_san's Avatar
if I will replace it with the standard rubber, you mean by putting the stock rubber?
Old Jan 26, 2012 | 03:58 AM
Kozy.'s Avatar
a.k.a. Komodo
If there is an option for you to replace the top mounts with a standard style one, whether they are from the coilover manufacturer or OE (if possible), then I would be doing that.
09 civic si
Honda Civic (2006 - 2015)
20
Aug 26, 2014 10:23 AM
IAcivicEK
Suspension & Brakes
Aug 15, 2007 11:45 PM
GS-R Power
Jul 27, 2006 02:43 PM
backyarddc5
Aug 20, 2004 03:40 PM
AsnRefugee
Sep 30, 2002 06:18 AM
