Which intake manifold?
Old Jan 24, 2012 | 04:46 PM
monster_c's Avatar
Default Which intake manifold?
What intake manifold would best suit a 84mm lsvtec with a ported gsr head?
Old Jan 24, 2012 | 07:32 PM
angryhillbilly's Avatar
Default Re: Which intake manifold?
off the shelf plenum style? prolly performer x. most power? prolly ITBs. modified oem? prolly a CNC'd ITR mani. depends on your budget and what the car will be used for.
Old Jan 24, 2012 | 08:15 PM
monster_c's Avatar
Do they make itr manifold for a gsr head?
Old Jan 24, 2012 | 08:42 PM
its called skunk2 pro =]
Old Jan 24, 2012 | 08:48 PM
GagnarTheUnruly's Avatar
Then why did you say ITR?
Old Jan 24, 2012 | 08:58 PM
oops. please forgive me! i neglected to remember that you had a gsr head and not a b16 head. although they do make an adapter plate to make the itr manifold fit on a gsr head. i just dont know if anyone has had any success with making power with it.
theres even a group of people who have had success modifying the stock gsr mani with butterflys. some type of CNC and port n polish work. but ether way i think your best bet will be to go with the skunk2 pro or the Performer X and port match it.
Old Jan 24, 2012 | 09:26 PM
monster_c's Avatar
I heard the performer x chokes the engine above 8000 rpm on a 2.0 liter. Don't know if its true our not. Does anyone know where I can still get a aebs intake manifold?
Old Jan 24, 2012 | 09:53 PM
TheShodan's Avatar
Moderator
You mean so it will do the same thing? Different manifolds have their attributes in different parts of the powerband. That's why you're getting seemingly conflicting answers. The engine displacement alone doesn't dictate which manifold you should get; the differences are based upon how the power you're looking for is delivered, and what the purpose of the car is Not just what rpm something goes to.
For example.
Longer runners on the plenum provide more midrange torque and power in the middle of the rpm range form 2500-7000rpms.
Types: Skunk2, Performer X, AEBS, King Motorsports Modified ITRs, etc.
Use: Midrange power, street, street/circuit, auto X , improved head packages, etc.
Short thick runners with a wide plenum provide more top end power at the higher rpm range of the powerband. Made for very large higher end setups from 4000-9500+ rpm ranges for NA or higher than 700whp for turbocharged applications.
Types: Golden Eagle, Magnus Motorsports, Edlebrock Victor X, Blueridge, AFI turbo, et
Use: Higher end power, aggressive turbo street, Street drag race, 61lbs/min + turbochargers etc.
So as to the question which is "best"? Answer: there is no "best".. only what's best for your needs and goals.
GL
Old Jan 24, 2012 | 10:57 PM
DirtyDA9's Avatar
If you are looking to keep some bottom end power, stick with the GSR manifold.
Old Jan 25, 2012 | 01:40 AM
cibao2ner's Avatar
on my 1.8l the performer x chokes the top end...get a modified performer x....
Old Jan 25, 2012 | 07:44 AM
chickenbandit's Avatar
For example.
GL
thanks
this answered my questions
Old Jan 25, 2012 | 10:23 AM
FlewByU352's Avatar
There was a test before on manifolds and for 2L setups I believe the ported ITR manifold made the most. In your case you would need a Skunk2 that is ported but the money for that I'm sure there is a much better option.
Old Jan 25, 2012 | 10:42 AM
jdmcx's Avatar
in the same boat with you i have a skunk2 gen1 on my gsr head and am thinking about going back to the stock gsr manifold after i get it ported a bit.
Old Jan 25, 2012 | 01:15 PM
Spawne32's Avatar
I dont see anywhere in your post what your top end is, because my top end is 7200rpm on my 1.8l.
Old Jan 25, 2012 | 03:04 PM
monster_c's Avatar
Thanks guys this just might answer my question
Old Jan 25, 2012 | 11:33 PM
wolve's Avatar
For example.
GL
the only correct answer, there's no best as it depends on goals, setup and preference of powerband.
shodan!
Sic_DA_Nine
Jun 23, 2006 01:26 PM
hondahans
Apr 9, 2006 08:45 PM
AK94GSR
38
Nov 29, 2004 09:42 AM
navin
Aug 23, 2004 07:31 AM
RICE POLICE SIP
Apr 4, 2003 01:39 PM
