Help Needed with Gear Shifter
First off, the car is:
2000 Honda Accord Se, automatic
166938 miles
The gear shifter usually will not change the gear of the car unless I unscrew the screw in the shifter and manually try different positions for the shifter to go down.
When I try to change gears, I press the chrome button and the whole **** moves up vertically. After trying different positions of the **** (with the screw out), the **** will change the gear of the car. Once the **** goes down, the shifter changes gears without a problem.
I am missing the spring that goes with the gear **** AND the screws which I believe go with the gear ****.
The "maint required" and "abs" lights turn on when the car starts, if it helps.
How do I fix this?
166938 miles
How do I fix this?
HopelessAccord
Nov 20, 2018 07:11 PM
DC5SMunky
Aug 13, 2005 09:43 AM
