Main Relay Clicking Fast While Cranking
Old Jan 24, 2012 | 02:38 PM
DirtyDA9's Avatar
Default Main Relay Clicking Fast While Cranking
After I finally got my car running, it started to get harder and harder to start, and while cranking, the Main relay would click really really fast. Takin8ez on here, sent me his old relay for free, today I put that on and it does the same thing. But this time I noticed the ECU's LED flashes every time the relay clicks, so it's flashing really fast.
About a month agot I checked and cleaned all my ground, so I know they are good, and I know a dying battery could cause the clicking, but I have jumper cables hooked up to another car, so it's not like it's not getting enough power.
I do not have an alternator belt on right now, I was waiting till I get a new one, and I haven't got around to it yet.
Any input is appreciated.
Old Jan 24, 2012 | 04:03 PM
TheRealTegger's Avatar
Default Re: Main Relay Clicking Fast While Cranking
What, precisely, happens when you turn the key to "II", and leave it there?
Please include the precise behavior of the Check Engine light, including any times (as in seconds duration) of specific events that you may observe.
Old Jan 24, 2012 | 04:20 PM
DirtyDA9's Avatar
I'm not exactly sure but I think my dummy lights were going on and off with the clicks. Which would make me assume battery connection or ground, but they are good.
When I leave it at "II" nothing really happens, I can hardly hear the fuel pump now too, I'm not even sure it primed this time.
Old Jan 24, 2012 | 04:28 PM
You're asking for help, and I'm trying to offer it. Vagueness on your part helps nobody.
When you leave the key on "II", does the Check Engine light come on for TWO SECONDS, then GO OFF? And during the time it's ON, does the gas pump whine? If you're not sure, remove the gas cap and have somebody listen at the open filler neck as the key is turned to "II".
Have you checked battery voltage with a multimeter? If so, do you see 12.65V and no less? Engine OFF, key OUT, I mean.
Please answer all questions, not just one.
Old Jan 24, 2012 | 05:43 PM
nahonda04's Avatar
Surje.motorsports
check engine light doesnt stay on when your at II?...I replaced mine after the clicking and havent had a problem since...its possible the one he sent you may have been faulty as well
Old Jan 24, 2012 | 05:46 PM
fcm's Avatar
fcm
Old Fart
You have an IM. 94
Old Jan 24, 2012 | 09:50 PM
DirtyDA9's Avatar
I'm not around my car or I would answer that for you, can't really tell you much by not being able to find out for you. Otherwise, I would be guessing, and that doesn't help anyone either.
And I would check the voltage at the battery, but it would be pointless, as the battery is dead, that's why I am using jumper cables.
Old Jan 24, 2012 | 10:07 PM
el crapitan's Avatar
sounds like a poor ground. possibly at the t-stat housing
Old Jan 24, 2012 | 11:00 PM
DirtyDA9's Avatar
Ok thanks guys. I cleaned all my grounds a while ago, but maybe not good enough on the thermo.
Old Jan 24, 2012 | 11:09 PM
also, check that the wires haven't become brittle with broken strands
Old Jan 25, 2012 | 05:12 AM
Fair enough.
If FCM gives you a working solution in his PM, it would be nice if it could be shared with those in this thread.
Old Jan 25, 2012 | 05:54 AM
takin8ez's Avatar
Like el crapitan said, I would inspect all the exposed wires in your bay. Specifically the injector wires. If there's a crack in the insulation and its touching metal it'll give you problems. Unfortunately, these problems are pesky and time consuming most of the time. Hope it helps.
Old Jan 25, 2012 | 06:08 AM
i was more referring to the ground wires at the cluster on the t-stat housing
Old Jan 25, 2012 | 02:37 PM
takin8ez's Avatar
I was more adding to what you said and contributing to the thread.
Old Jan 25, 2012 | 02:55 PM
DirtyDA9's Avatar
Fair enough.
Will do. Odd's are it will work out, FCM is alway right lol.
Old Jan 25, 2012 | 03:01 PM
DirtyDA9's Avatar
Thanks guys didn't get a chance to try to diagnose it today, I will tomorrow, and post up FCM's advice.
Old Jan 25, 2012 | 04:55 PM
cool beans, bud
Old Jan 25, 2012 | 05:51 PM
DirtyDA9's Avatar
Originally Posted by el crapitan
cool beans, bud
http://youtu.be/nwVkjheanQk
Old Jan 25, 2012 | 07:22 PM
andy sandberg is the fricken man
Old Jan 25, 2012 | 07:48 PM
DirtyDA9's Avatar
I'm on a boat bitch...
lol when you said cool beans he was the first person to pop in my head
Old Jan 26, 2012 | 02:31 AM
Solster's Avatar
i just had sex
Old Jan 26, 2012 | 11:19 AM
DirtyDA9's Avatar
Originally Posted by Solster
i just had sex
Did you jizz in your pants?
Old Jan 26, 2012 | 09:33 PM
standy xsi's Avatar
After making love with your mother?
Old Jan 27, 2012 | 12:06 AM
Solster's Avatar
when i was thinking about jack sarrow
LOL
Old Jan 27, 2012 | 11:38 AM
DirtyDA9's Avatar
Remember the safe word is Hwiskey
pyroom
12
Apr 6, 2025 10:42 AM
spencerxfr3sh
Feb 23, 2009 05:42 PM
shreddinryguy
Jun 26, 2005 02:03 PM
triple_s1x
Feb 27, 2005 11:10 AM
4doorH22
Apr 16, 2002 07:16 AM
