What is the function of this hose?.
Old Jan 24, 2012 | 09:18 AM
dishjuarez's Avatar
Default What is the function of this hose?.
Thank you.
Old Jan 24, 2012 | 09:20 AM
dishjuarez's Avatar
Default Re: What is the function of this hose?.
Is marked with a red circle.
What happens if are disconnected?
Old Jan 24, 2012 | 09:21 AM
grumblemarc's Avatar
The Grumpiest
What car is this in? I don't have that in mine. Where does it go to? Post all that info if you don't want your thread locked.
Old Jan 24, 2012 | 09:25 AM
dishjuarez's Avatar
Is true.
Is a Honda Civic 98 LX, and is the fuel filter above.
Old Jan 24, 2012 | 09:26 AM
The Grumpiest
I know it's the fuel filter. Where's the other end of the hose go to?
Old Jan 24, 2012 | 09:30 AM
dishjuarez's Avatar
Let me find out then, because this morning I realized that was unplugged and plugged it alone.
Thank you.
dishjuarez's Avatar
Sorry is google traductor...
Old Jan 24, 2012 | 09:31 AM
dishjuarez's Avatar
Let me find out then, because this morning I noticed I was disconnected and plugged.
Thank you.
Old Jan 24, 2012 | 09:32 AM
The Grumpiest
No worries. You communicate better than some real English speaking people on this forum.
Old Jan 24, 2012 | 09:35 AM
dishjuarez's Avatar
The car is well, but when I go to 40M or so leave the car speed up and slow down very quickly
Old Jan 24, 2012 | 09:41 AM
speedooo's Avatar
Looks like the 50/12/22 area
dishjuarez's Avatar
Thanks for this great forum...
that's what I said.
Old Jan 24, 2012 | 03:00 PM
Humphrizzle's Avatar
to vent gas fumes most likely through the charcoal canister.
your stuttering/hesitation problem is most likely not going to be part of the evap.
Old Jan 24, 2012 | 07:54 PM
Steezer's Avatar
i would also like to know what it does. how does it vent fumes? the end of the hose is connected to the filter clamp. Its something thats been rattling my mind on my filter change. Btw i have a 97EX d16y8
Old Jan 24, 2012 | 08:37 PM
the other side goes to a 3 way valve which connects to the charcoal canister. the hose connects into the clip which is also a possible releif valve.
it's what makes sense to me. no proof, just hypothesis.
Old Jan 25, 2012 | 02:08 AM
jbpnoman's Avatar
FWIW, I've had mine disconnected since I did my turbo install (completely unrelated) and haven't had any problems.
Old Jan 25, 2012 | 02:14 AM
lordbucanero's Avatar
I have the same car as you and I don't have this hose
Old Jan 25, 2012 | 09:33 AM
Steezer's Avatar
Maybe because you live in Spain? I have a U.S. model.....
Old Jan 25, 2012 | 02:32 PM
vtechjunkie's Avatar
It goes to the charcoal canister. Has nothing to do with your cars issues. Check your icm in the distributor, and also make sure there are no leaks into the combustion chamber or spark plug area. I had the same issue and it turned out to be the distributor. Does the tach do anything while the sputter is happening? More symptoms?
jeffy
10
Dec 4, 2017 11:59 AM
bleedblue94
Jun 15, 2004 07:00 PM
StupidSlowRSX
Apr 26, 2004 08:26 AM
Dan GSR
Jan 22, 2003 10:03 AM
