skunk2 pro2 or pro3
Old Jan 24, 2012 | 02:54 AM
chickenbandit's Avatar
Default skunk2 pro2 or pro3
ok so my build is progressing very rapidly
and this thought just randomly popped into my head today
I want to make 240whp allmotor
should i start looking for another set of cams to trade for
if so lmk and what hp do you allmotor heads think ill achieve
my setup
b20z
84.5 endyne rollerwave pistons midtops (12.5-.8:1cr)
will have a standard 3 layer headgasket
eagle LS rods w/ arp rodbolts
LS/b20 micorpolished & balanced crank
z10 block girdle
arp headstuds
arp main studs
8lb flywheel 6puck cc clutch b16 cable trans
type R head with all supertech internals
skunk2 pro2 camshafts
w/ port match to head - skunk2 first gen mani
70mm throttle body (manifold portmatched to throttlebody)
smsp header
440 injectors
walbro fuel pump 255lph
car will be dynoed on e85 (unless advised to go another direction)
this will be going into a 90 crx
i really wanna make 240whp+
so should i upgrade to a pro3 or will it be overkill
if not a pro3 then what is the best cam suitable for my build
and should i run e85 will i benifit from it
my budget is very low so i will be trying to trade for another cam
if it will benifit me
Old Jan 24, 2012 | 05:05 AM
Mhollaek9's Avatar
Default Re: skunk2 pro2 or pro3
I had a very similar build with a budget header on pump 93 same cams gsr head and made 220. 160 no portmatching 68mm tb rs machine pistons 84.5. Being that your head header and tb are bigger you should yield more. Make sure your run at least a 2.5 exhaust.
Old Jan 24, 2012 | 05:58 AM
itll probably get tuned open header and be raced open header
since i have need to daily drive this. what cams did you have?
Old Jan 24, 2012 | 01:41 PM
Colman787's Avatar
i'd say your about there now with pro 2's, did u ever dyno this setup?
Old Jan 24, 2012 | 03:43 PM
no havnt dynoed yet
should be in about a month.
the engine will be complete tonight
just making sure that i dont want to make
any last minute changes
Old Jan 24, 2012 | 04:18 PM
DDTECH's Avatar
Dont start that engine @ 0/0.
Old Jan 24, 2012 | 10:39 PM
that wont be an issue since i just picked up some sk2 pro gears
now another question is what degree to start at
Old Jan 25, 2012 | 03:30 AM
Uncle Dave's Avatar
Degree the cams to Skunk2's supplied spec's
Old Jan 25, 2012 | 07:28 AM
b20vtek's Avatar
x2
Old Jan 25, 2012 | 07:38 AM
ok ill do that
1stGenCrxRobby
18
Aug 28, 2015 02:35 PM
Superqwak
Feb 23, 2012 08:04 PM
ChrisEK9
13
Mar 10, 2010 10:54 AM
ChrisEK9
Mar 7, 2010 12:32 PM
GotRHD
22
Oct 30, 2009 08:44 AM
