Arp rod bolts Torque
Looking for the torque setting for a b16a arp rod bolts.
I have searched and found 50 ft-lbs.(also found 43 ft-lbs and 46 ft-lbs)
Standard bolts are 30 ft-lbs seems like a fair jump so just double checking
Thanks Eugene
Thanks Eugene
Just making sure here cause it seems a little high is all better safe than sorry.
The paper on the box from the last B series I did said 45. Use the moly lube for that, and have the big end of the rod bore blueprinted to spec after the bolts have been pressed in.
Yes I know here is the link,
http://arpinstructions.com/instructions/208-6401.pdf
but 50 is much more that OEM
i am currently having issues with same matter. i have b16 rods, re-sized crank ends w/ arp rod bolts...
at 40ft lbs, which arp states in instructions, my rods can move side to side???? idk if i should crank it up to higher torque
H22coupe
Apr 30, 2004 05:24 PM
