My civic smokes like crazy!
Old Jan 23, 2012 | 01:23 AM
blasta510's Avatar
Default My civic smokes like crazy!
Ut o
http://www.youtube.com/watch?v=RzuZ0...2&feature=plcp
Old Jan 23, 2012 | 01:35 AM
etienne.cpt's Avatar
Default Re: My civic smokes like crazy!
(did not view the video but)
Have a compression test done. Piston rings might be fried.
check head gasket (do a leak down test)
Dc4LsTeG's Avatar
EK9
Your question?
Old Jan 23, 2012 | 02:16 AM
blasta510's Avatar
Originally Posted by Dc4LsTeG
Your question?
What do you think it could be?
Old Jan 23, 2012 | 02:44 AM
jmarshall098's Avatar
When tail pipe starts smoking, may be its trouble time my friend. Looks kind of white smoke from the video. Hence may be your Head Gasket is damaged and due to this anti-freeze has entered the cylinder.
Old Jan 23, 2012 | 04:19 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
"Hey, uh ya, y0, tubular dood, sumtin Wong wit my cah, imma jus keeps beeten on it"
You do realize you can ruin more by doing the things you did in the video correct? In the begining there was bluef-ish smoke which indicates either the rings or valve guides/seals. Then the billowing white smoke shows coolant is getting into a cylinder/s severely. So, there is a high possibility this engine needs a complete overhaul. If you don't have the money for that then either a headgasket change or engine swap would suffice. I somewhat sense a "jokester".
PS - It's never a good idea to rev a cold engine. Things aren't lubricated properly yet.
Old Jan 23, 2012 | 06:45 AM
88EFsedan2's Avatar
Rings mite be bad that happen in my zc but you also wanna get rid of that airbox an stock exhaust at least muffer an I always take off cat mine smoked less after cus the airbox makes it run rich
Old Jan 23, 2012 | 08:18 AM
DO IT ON ALL FOURS
I hope you aren't serious about ANY of your post.
Old Jan 23, 2012 | 10:04 AM
DCRB's Avatar
ahhhhhhhhhhh bone stock ex sedan ftw!!
smoke is BAAAAAAAAAAD. i'm thinking head gasket.
what's it smell like? kind of sweet? definately coolant.
lots of blue smoke? oil from bad rings.
don't just discount that a6 you have there, its a peppy little engine when in tip top shape, i love mine.
if anything i'd pick up a low mileage zc from hmotors online and swap that over
Old Jan 23, 2012 | 11:43 AM
singlecamsaint's Avatar
i would totally buy this car from you lol
Old Jan 23, 2012 | 12:39 PM
.Manny.'s Avatar
Touching My Member
Leakdown test. Only way to zero in on the problem.
Old Jan 23, 2012 | 08:38 PM
blasta510's Avatar
Smoke is blue and does not smell sweet
Old Jan 23, 2012 | 08:39 PM
man thats a rare car....i want! i dont care that its automatic lol.
Old Jan 23, 2012 | 08:48 PM
88HATCH(:'s Avatar
holy damn , i want !!
leakdown test will tell you fersure .
Old Jan 23, 2012 | 09:58 PM
codybuRr's Avatar
he's got it.
the OP knows nothing about hondas :/ i doubt its going to be an easy fix,
you should just let me buy taht EX from you.
Old Jan 24, 2012 | 02:29 AM
i would totally make the op an offer but i know he isnt local to me
Old Jan 24, 2012 | 02:38 AM
88LsRex's Avatar
theres 2 Burgundy EX sedans UNTOUCHED at a local junk yard around here.
Old Jan 24, 2012 | 02:45 AM
really....ive only seen one in my entire life and a buddy of mine owns it. lucky
Old Jan 24, 2012 | 08:05 AM
asianflava's Avatar
Looks like a bad head gasket to me. Not much smoke at first but got worse when it warmed up. Also looks like you need to put the rubber bumper on the brake pedal arm.
mannydhanju
Aug 21, 2009 05:46 AM
GSR936
Apr 28, 2009 06:10 PM
chu77
May 25, 2006 07:55 AM
som3on3_10
May 20, 2006 05:49 PM
All Motor EG
Jul 22, 2002 09:48 AM
