Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anyone track thier Em1?
Old Jan 22, 2012 | 04:06 PM
Huss's Avatar
Default Anyone track thier Em1?
hey i havent posted on here forever but here is my Stock 2000 Civic siR i have had this car since April bought it with 120,000kms(75k miles) since the i replaced the Timing belt/tesnioner/seals/water pump/thermostat, tranny fluid change, and spark plugs+valve adjusment i also added JDM password intake since it had a ghetto setup before and i just recently added the Hids for night driving.
some pics of my engine bay.
anyway i was just wondering if any EM1 owners have any track experience...Since my car is mechanically sound, I am planning on tracking it this summer. Ok So to my knowledge, first I need a DOT approved helmet? And for tires I want to run my stock wheels but I need help choosing some decent track/ summer tires in 15"Also about the brake pads and rotors? Should I upgrade or run stock? And for suspensions run the car stock first and then see what needs to be upgrade? Please don't be afraid to chime in!
Thanks! Forgot just hit 98,000 Miles!
Old Jan 22, 2012 | 04:16 PM
kungfuSiR's Avatar
Default Re: Anyone track thier Em1?
Fellow EM1 owner here. Since its sounds like you don't have much track experience it would probably be best to just keep the car stock for now and learn as much as you can.
Just make sure your car is mechanically sound, make sure to put some fresh brake fluid before you head out and check that everything is working as expected. You'll know once you've gotten comfortable with the car what needs to be upgraded next.
As for summer tires Hankook RS3s are probably the best DOT street tire you can get, also the Dunlop Star Specs are pretty darn good.
Old Jan 22, 2012 | 04:20 PM
Huss's Avatar
That was quick Awesome!
well i know that i need to upgrade the Rotors very bad. since there is a little bit of vibration when braking at highspeed. Thinking of some SLotted/drilled rotors and Hawks pads? also for the tires i have heard some good stoires about the Dunlop star. what size would you recommend? and for the brake fluid just some 4 Dot approved?
Old Jan 22, 2012 | 05:00 PM
vtecing's Avatar
as for your brake rotors, if they arent too worn you could just have them machines so they are like new again. For light track work in a stock car oem rotors should be fine. Get some decent brake pads and some good tyres and you will have a lot of fun.
After you get a feel for the car you will probably realize it is a boat, the next step would be coilovers and rear sway bar. Track it again and go from there...
Old Jan 22, 2012 | 06:08 PM
JDMEMone's Avatar
I track my em1 all day long! great platform!
Old Jan 23, 2012 | 03:00 AM
Lo-Buck EF's Avatar
No drilled rotors. The cheap parts store ones work just fine.
You should get good fluid (ate type 200/super blue, ect) and good pads (hawk dtc30, ht10), and a good street tire. That is all you need for a while.
Happy motoring!
Old Jan 23, 2012 | 04:21 AM
Tight-R's Avatar
And
Happy motoring!
Old Jan 23, 2012 | 06:07 AM
chad's Avatar
Moderator
i track the **** out of my em1 k powered car!!
Old Jan 24, 2012 | 06:21 AM
Lo-Buck EF's Avatar
Yea, you do!
Old Jan 25, 2012 | 07:38 PM
CivicSiRacer's Avatar
I took an HPDE at VIR back in 2002 with my EM1. The only thing I would recommend is flush the brake fluid with something better and upgrade the pads (as long as your rotors are ok) with something like Hawk HPS or HP+ pads.
I toasted my pads and fluid the 1st session out. Pedal went to the floor when I tried to slow down. Scary as heck. I didn't know as it was my 1st track day and the internet was still in it's infancy.
Also make sure your gas tank is topped off as you will go through gas quick I ran on my Falken Azenis and had a blast.
Old Jan 25, 2012 | 09:07 PM
20CiviC02Si's Avatar
Yeah i track my EM1 SSC race car regularly. Bought it from a good friend when she could no longer race due to class rules. I run R Comps and some pretty hardcore brake pads on OEM rotors. Don't need much more than that.
However for a rookie, street tires on stock wheels with good pads and oem rotors will suffice. Just make sure to use a good brake fluid like ATE Superblue, bleed them before you go out to the track.
No more vinyl on the car now!
Old Jan 26, 2012 | 07:18 AM
weasel1's Avatar
I tracked my em1 when it was standard, i tracked it during modification and I will be tracking it as an all out race car very shortly.
As a minimum, you should look at the following before going to a track:
1. Change brake fluid to a good brand with high boiling temp. Motul RBF660 is a good option.
2. Make sure you have good brake pads and good disks with loads of meat.
3. I would reccomend a upgraded seat and harness as you will slide out of the standard factory seats on fast sweeping corners.
4. Decent brand of tyre depending on your budget
5. A torque wrench or power-bar for tightening your wheel nuts.
Also consider welding some baffle plates into your sump. This comes highly recomended if your going to track your car regularly.
Heres a pic of me last year...coming up to lap that integra or course :D
Old Jan 26, 2012 | 07:43 PM
RBF 660 is a bit pricey for just getting your feet wet. ATE Superblue and others are far cheaper alternatives for an HPDE. The higher modified cars and racecars use fluids with a minimum of 600 degrees boiling temp, due to their performance potential being far greater.
Old Jan 27, 2012 | 05:13 AM
weasel1's Avatar
ATE is actually more expensive than the motul rbf where i am!
Old Jan 27, 2012 | 06:42 AM
Damn i want to have that problem! LOL! How much are you paying per bottle?
Old Jan 27, 2012 | 11:23 AM
weasel1's Avatar
14Euro per bottle.
ATE is nearly impossible to get...its like 40Euro a bottle!
Old Jan 27, 2012 | 12:54 PM
Funny almost the exact opposite problem here! Well for you Motul RBF660 it is!
Old Jan 31, 2012 | 01:00 PM
Huss's Avatar
thanks for the reply guys.
yes rotors are toast. going to order some cheapo ebay ones. btw would the dealer ship change the fluid for me? i want this car to be dealer maintained.
Old Jan 31, 2012 | 01:20 PM
Calif_Kid's Avatar
If you're going with Motul brake fluid, then maybe go with RBF600 instead of RBF660. The RBF660 is rated somewhat higher, but costs quite a bit more. The RBF600 may sufficient and may also be easier to find if you need extra at the track. Make sure that you do a really good flush of the whole system if you're switching over to a new brake fluid (you can empty out the master cylinder reservoir and fill it with the new fluid before starting to flush the lines). The racing fluid like Motul RBF600 absorbs moisture faster than standard (non racing) fluid, so you'll want to bleed the lines periodically afterwards, and do a full flush say once a year. - Jim
Old Jan 31, 2012 | 08:25 PM
I wouldn't order eBay cheapos. You should get something like Brembo OE replacement, or part store brands. That way you can at least ensure that they use quality metals that are going to be temperature consistent. I never really trust anything sold on eBay, especially when it comes to important parts of the car, and those parts going wrong could cost me the car or my life.
Old Feb 12, 2012 | 06:26 PM
Huss's Avatar
would it hurt to run 5W40 synthetic?
Old Feb 12, 2012 | 08:12 PM
I just run regular 5w30 Mobil1
Old Feb 13, 2012 | 03:13 AM
weasel1's Avatar
Was just out for a test session saturday gone by.
Heres a few pictures:
Old Feb 13, 2012 | 07:16 AM
Huss's Avatar
it just burns oil now with the 5w30 but again i am almost in vtec thats why i wanted to upgrade to heavier oil.
Old Feb 13, 2012 | 10:27 AM
kungfuSiR's Avatar
Is that a set of wing risers on a Mugen wing? How do you find it?
