LOS02 MEGA GARAGE SALE
Cleaning up everything in my garage. Have a lot of parts laying around that I don't need. I will be updating this list regularly. Accepting all reasonable offers. Everything is in working condition unless otherwise noted.
ECU's
PR4 $50
PR4 $50
P8F $100
PM9 $80
1990-1993 ACURA INTEGRA PARTS
DA Integra LS - Master Cylinder $25
DA Integra LS - Brake Booster $50
DA Integra - Window Regulator (Left) $50
DA 90-93 Integra - Vehicle Speed Sensor $80
Belt Warning Control- $30
DA Integra - Front Wiper Motor $40
DA Integra - 40 40 Proportioning Valve $40
DA Integra – Glove box $20
Fuel Door / Trunk Release Cover $5
DA Integra – OEM Fuel Rail $40
DA Integra - Overflow Tank $20
DA Integra – Corner light (Left) $10
Shift ***** (2) $10
LS – Exhaust Heat Shield $10
DA Integra - Speedometer Cable $20
DA Integra – Starter $40
DA Integra - rear hatch glass $80
1988 1989 1990 1991 HONDA CIVIC HATCHBACK
EF Civic – Antenna (Complete) $20
EF STD - Engine Wiring Harness (Complete & Uncut) $100
D-15 manual starter $30
EF Civic SI - Sunroof assembly w/ motor (no glass) $40
EF Civic - Hatch Drivers Window glass $40
Gauge Clusters (no tach) $50 <br>
DEL SOL PARTS
Del Sol power steering rack (from tie rod to tie rod) Came off of a 97 SI.
Del Sol manual rack (from tie rod to tie rod)
Del Sol center console (radio and shifter section) black
Del Sol gauge clusters
Del Sol gauge cluster bezel with buttons
DC Integra All off 1994 GSR coupe
steering column
Headliner
Sunroof assembly (with motor and glass)
DC Integra GSR front strut bar $20
DC Integra sunroof sunshade (2DR GREY) $20
DC Integra instrument gauge bezel $10
DC Integra fuel door (red) $10
DC integra steering wheel black no airbag $40
DC Integra driver door handle panel w lock switch $10
DC Integra power steering pump $20
DC Integra AC compressor $20
DC Integra combination switch (turn signals and wipers) $20
DC Integra driver door wiring w. power window control unit $20
DC Integra hatch struts $20
DC Integra blower motor $20
DC Integra blower motor resistor $20
DC Integra hubcaps (all 4) $20
DC Integra charcoal canister $20
DC Integra sun visors (grey) both $20
DC Integra windshield wiper motor $20
1999-2000 CIVIC SI EM1 PARTS
1999 SI complete OEM REAR suspension (includes brake bads,rotors, calipers, struts, springs, tie rods, sway bar, e brake cables,trailing arms) SOLD
EK gauge bezel
cup holders
99 SI climate control conversion (climate gauges, bezel, harness, heater box and blower motor)
MISCELLANEOUS
EG no tach Gauge Cluster $50
Pilot - Steering Wheel (Aftermarket) $50
Megan Racing Bars will fit EG and DC (5 bars) - C Pillar Bar, F/R Lower Tie Bar, F/R Upper Strut <b>WILL NOT SEPARATE!!! $250
Used Cone Air filter (Aftermarket reusable) $40
D15B7 in running condition, does not over heat $200
EK EX 5 speed Gauge cluster with 85K $100
TEXT: 443-564-9376 PLEASE DO NOT CONTACT AFTER MIDNIGHT
I have alot more parts to list but I am doing this from my phone and will add more when I get to my computer.
ECU's
PR4 $50
PR4 $50
P8F $100
PM9 $80
Shift ***** (2) $10
DEL SOL PARTS
steering column
Headliner
EK gauge bezel
cup holders
MISCELLANEOUS
mac51o
Northern California (Sales)
23
Apr 18, 2011 11:18 AM
chocolatesk8er10
Texas -OK -LA (Sales)
15
Feb 25, 2010 08:29 PM
