Harmonic Balancer - right or left handed bolt?
Old Jan 22, 2012 | 01:45 PM
awjuhl's Avatar
Default Harmonic Balancer - right or left handed bolt?
I Have a D15 and I need to get the harmonic balancer off the engine. Is it right or left handed bolt.
Old Jan 22, 2012 | 01:49 PM
98civdx's Avatar
Master Detailer
Default Re: Harmonic Balancer Help
It is not a backwords threaded bolt.
But, it's a pita to remove.
Old Jan 22, 2012 | 01:52 PM
awjuhl's Avatar
i noticed that it is hasn't moved yet
Old Jan 22, 2012 | 02:05 PM
Dc4LsTeG's Avatar
EK9
You need to use a chain wrench to stop it from spinning or a strong enough impact gun
Old Jan 22, 2012 | 02:07 PM
98civdx's Avatar
Master Detailer
That or rent the crank pulley tool to hold it.
You will need a big *** pry bar with cheater pipe, OR, a impact with at least 1000-1200lbs of brake away torque.
I faught mine for 2 days, and gave up. I took it to a shop and they broke it free for me.
Old Jan 22, 2012 | 02:09 PM
Dc4LsTeG's Avatar
EK9
Idk why people always have problems with it. I use a chain wrench everytime and never had a problem and everytime the bolt is torqued correctly
Old Jan 22, 2012 | 02:21 PM
k94cvtec's Avatar
the good thing is once you get that bolt out the pulley should come right off! at least the last 10 I'v done have. using an air impact wrench is the only (efficient way) in my opinion. hope this helps.
Old Jan 22, 2012 | 02:30 PM
hannslebo's Avatar
As 98civicdx said - crank pulley tool!
Best thing to use! Use it with a breaker bar or impact.
Most def the easiest way...I bought off amazon and used it for mine. I sold it to my mobile mechanic buddy for 10 bucks and he uses all the time and says its one the handiest tools he has! I think you can rent them too.
http://www.amazon.com/Powerbuilt-648.../dp/B0000TMLWQ
Old Jan 22, 2012 | 02:57 PM
awjuhl's Avatar
i got it off by putting two bolts in the holes in the balancer and putting a pry bar through them
How do you time this engine like how do the marks have to point I didn't see any marks on the block
Old Jan 22, 2012 | 03:24 PM
k94cvtec's Avatar
what you have to do is put the plastic cover back on and slide the pulley back on. Line up the pulley mark with the mark on the timing cover. your good to go
Old Jan 22, 2012 | 03:28 PM
awjuhl's Avatar
are there any other marks for it that aren't on the cover or any one wanna sell me one cheep mine is MIA
Old Jan 22, 2012 | 03:31 PM
k94cvtec's Avatar
when your ready to time the cam you put the UP on the cam pulley facing up and the timing mark needs to line up with the front of the head. (THE SURFACE WERE THE VALVE COVER MEETS UP WITH THE HEAD) the mark on the cam pulley should be facing straight forward. hope this helps
Old Jan 22, 2012 | 03:37 PM
k94cvtec's Avatar
if you cant find any marks just put the #1 piston at TDC (top dead center) and make sure all the valves on that cylinder are closed to ensure it is on the compression stroke. then you should be good to go
Old Jan 22, 2012 | 04:29 PM
awjuhl's Avatar
thank you all i got it running just got to put the alt back on and the tire
again Thankx
Awjuhl
Old Jan 22, 2012 | 04:43 PM
98civdx's Avatar
Master Detailer
Default Re: Harmonic Balancer - right or left handed bolt?
There is V shapped thing on the lower timing cover. There is white line on the pulley. put that white crack in the V and the crank is at tdc.
Don't forget to set the cam at TDC!
MagicUnicorn
24
Apr 28, 2022 02:45 PM
projsectEF
Sep 21, 2007 03:53 PM
WRXRacer111
23
Jan 20, 2006 02:36 PM
shutta
Nov 13, 2005 02:34 PM
ebelp
May 13, 2003 03:49 PM
