6 in 1 merge collector help needed!
Hello everyone.
I am coming with a tricky question.
I want to fabricate a 6 in 1 merge collector and I have absolutly no clue on how to do it.
So....if there's anybody out there who can help me please do so!
I am really desperate because I have a client waiting and I don't want to dissapoint him!
Cheers!
B
Cheers!
B
Wouldn't it be a 60* cut for all six pieces??..Don't forget to account for blade deflection if you use an abrasive saw. 11.5 is a good intersection angle but you will need more length in the collector.
I think that for the 4 ones on the outside is enough but about the 2 ones on the center....you need to do 3 cuts on them not only 2 like on the other 4.
Please do tell!
Just look at this thread you should be able to figure it out pretty easily.
https://honda-tech.com/forums/welding-fabrication-53/6-cylinder-merge-collector-2561868/
Just practice with PVC pipe till you get it right.
6-1's are a 60 degree rotation in each direction from the 0 plane. With splayed collectors the 0 plane is wherever you reference your first cut from. With parallel collectors, the 0 plane is referenced where the center line of tube rotation and the cutter are perpendicular.
Thanks crmb.
So...basicly it's an 120 deg rotation?
I can't get how do you make the center ones??
Could you,please, be more explicit?
Thank you very much!
SMH. if you want a circle outlet 120 deg rotations will create a circle outlet.
if you want a rectangle. the two outer pipes on each side are made just as if it were a 4-1 collector but the 2 inner ones are cut 180 degrees from eachother. meaning like a perfect Y to splice in the middle. creating a 6-1
Thanks Thanks Thanks!!!!!!!!!!!
actually you have confirmed what I was thinking............but thanks for the input.
It is much more than helpfull.
Cheers for that!
Cheers for that!
Spugen_eg
Audio / Security / Video
Nov 26, 2007 05:42 PM
hatchyboy89
Aug 23, 2005 09:46 PM
