95 hatch/b18 swap sat for about 10 months - Now motor has weird power loss
Ive got a 95 hatch with a b18 motor. It sat for about 10 months before I got it running. At anywhere from 25% to 50% throttle the car seems to lose power. And I got a vibration (solid mounts) all over the car like a cylinder is missing really bad. The Ecu is a phearable chipped and I've replaced plugs, wires, ignition control module and coil. It cleaned up a little but still not 100%. Any ideas?
Then, Without any real info to go on I'm going to have to say it's your basemap because "seems like" isn't really an accurate description.
What color is your spark?
Well, the loss of power is there. the car falls on its face. I hope it's not the basemap. Spark is good and strong. A friend of mine said maybe a tps but I don't think that would cause it. It's only when it's under a load.
Did you test all your spark plugs? I had a problem like this once, it was a spark plug wire that went. it was like hitting a brick wall. Just something to rule out i guess.
efcivic757
Jun 22, 2006 03:12 PM
95prludevtec
Jun 7, 2005 09:43 PM
EK9 B16B TSL
15
Feb 12, 2005 12:38 PM
