93 si hatch/gsr swap with code 14
Old Jan 21, 2012 | 06:29 PM
eg6king!!!'s Avatar
Default 93 si hatch/gsr swap with code 14
Ok now i own a 93 si eg hatch it has a gsr swap and its throwin a cel for iacv ive tried 4 different ones and changed wiring harness it still is throwin it wat else could it be???
Old Jan 21, 2012 | 08:27 PM
MTracing's Avatar
Default Re: IACV Problem
Is the car idling funny??
Maybe try a new ECU??
**make sure all the connections are clean. Follow the wire and make sure the wire is good. Check the connection to the ECU
Old Jan 22, 2012 | 05:05 AM
HondaPartsHero's Avatar
Technical Hero
Did you clear the code to see if it comes back
Old Jan 22, 2012 | 08:48 PM
eg6king!!!'s Avatar
Default Re: 93 si hatch/gsr swap with code 14
@ MTracing it idles really low and i will check all connections
@HondaPartsHero i have clear the codes and it still comes back
Old Jan 22, 2012 | 11:22 PM
MTracing's Avatar
Ok, well here is a link from HT that you can look into and try to fix it
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/idle-surging-hunting-idle-lets-fix-now-343980/
Old Jan 23, 2012 | 07:00 AM
Cynical 1's Avatar
is the correct connector plugged into it?
evap solenoid and iac are similar plugs and easy to confuse.
Old Jan 24, 2012 | 11:58 PM
MTracing's Avatar
You can also check for a vacuum leak. It's as simple as pliers and squeezing a few hoses for the idle issue. Check the hoses going from intake to engine.
Chase420
11
Apr 12, 2013 11:20 AM
nkcalvert09
Apr 25, 2011 06:48 PM
91efbluehatch
Mar 19, 2011 09:45 AM
jdoggmr2
Jun 25, 2006 03:44 PM
