93 si hatch/gsr swap with code 14
Ok now i own a 93 si eg hatch it has a gsr swap and its throwin a cel for iacv ive tried 4 different ones and changed wiring harness it still is throwin it wat else could it be???
Re: IACV Problem
Is the car idling funny??
Maybe try a new ECU??
**make sure all the connections are clean. Follow the wire and make sure the wire is good. Check the connection to the ECU
Re: 93 si hatch/gsr swap with code 14
@ MTracing it idles really low and i will check all connections
@HondaPartsHero i have clear the codes and it still comes back
Ok, well here is a link from HT that you can look into and try to fix it
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/idle-surging-hunting-idle-lets-fix-now-343980/
You can also check for a vacuum leak. It's as simple as pliers and squeezing a few hoses for the idle issue. Check the hoses going from intake to engine.
Chase420
11
04-12-2013 11:20 AM
nkcalvert09
04-25-2011 06:48 PM
91efbluehatch
03-19-2011 09:45 AM
jdoggmr2
06-25-2006 03:44 PM
