Crankshaft oil seal
Old Jan 21, 2012 | 05:59 PM
MyCivic99's Avatar
Default Crankshaft oil seal
I own a '99 Civic EX and the crank seal has given up on me. I'm replacing a quart of oil at each fill up right now and need to get this fixed. Do I need to pull the engine to replace it or is there hopefully an easier way?
The Civic just rolled 160K and I need to replace the timing belt as well. So I'll be doing this at the same time.
Thanks for any input!
Old Jan 21, 2012 | 09:34 PM
Texas4door's Avatar
Default Re: Crankshaft oil seal
Nope, you can easily pull this seal out once you remove your harmonic balancer when you do your timing belt
It looks like a big gasket that sits around where your oil pump is attached to the crankshaft
Just don't lose that woodruff (sp) key!!
As for a temporary fix till you have decide to replace the belt/water pump/seal/all that fun stuff:
http://www.amazon.com/White-Shepherd.../dp/B002BG2OHI
Don't trust the shitty reviews by only three customers
Worked wonders on mine in like a week! 8D
OR you can overpay for this:
http://www.amazon.com/Lucas-10278-En...=pd_sbs_auto_7
Better reviews but ya gotta keep adding it every oil change
At least the White Shepherd stuff is a one-time thing
Good luck!
Old Jan 21, 2012 | 09:40 PM
98civdx's Avatar
Master Detailer
The seal is a peice of cake to replace, now getting to it is another story. It's a PITA to get to it.
Hop on ebay and look around for OEM t-belt kits. I got mine from DCHonda(or something like that) for $149 shipping, and it came with cam/oil seal, water pump, timing belt, and all 3 others.
This is your best bet.
Old Jan 22, 2012 | 08:08 PM
MyCivic99's Avatar
Thanks for the quick replys. I'll be getting my hands dirty here soon and I'll let you know how it goes. As for the job at hand I feared it would be a pain to do it, but it'll be a good learning experience.
Do any of you by chance have a link to a step-by-step tutorial on what I'm about to do? Thanks!
Old Jan 22, 2012 | 09:28 PM
98civdx's Avatar
Master Detailer
Not step by step, however I just did my t belt/water pump in may, and I need to pull everything back apaprt due to my front main, may be leaking.
Either post in here and I/someone else can answer it, or feel free to pm me. i'll do my best to help you out.
Old Jan 22, 2012 | 10:13 PM
Texas4door's Avatar
You know, if someone makes a DIY for it, we should sticky it because I don't think a sticky for it exists atm...
Old Jan 23, 2012 | 10:39 AM
98civdx's Avatar
Master Detailer
They wont sticky it, but I am sure something exsits somewhere around here. I didn't look very hard.
Old Jan 23, 2012 | 07:55 PM
MyCivic99's Avatar
So to recap...
Texas4door: I'll replace the timing belt and while that's off, remove the harmonic balancer and then I can access the crank seal? No need to lift the engine out right?
From 98civdx: Purchase an OEM tbelt kit and that will have everything I need for this job including the crank seal?
If that isn't right, let me know, thanks guys!
Old Jan 23, 2012 | 08:39 PM
98civdx's Avatar
Master Detailer
Here ya go, http://www.ebay.com/itm/HONDA-GENUIN...item4aaed8d49d
This has everything except for the tensoner. The prices seems to have gone up $49, BUT, it's still cheaper then what you will get at the dealer, and better then any parts store ****.
You don't need to remove the engine, but you will need to jack up the engine, and support it to remove the driver side engine mount.
A jack will do for this, but use a block on the jack to help protect the oil pan.
Mr. Future
Feb 6, 2013 11:29 AM
black0hatch
Feb 13, 2010 06:59 AM
pootie.teng
12
Mar 22, 2007 09:09 AM
crxdriver89
Mar 13, 2006 01:49 PM
snatch
12
Mar 15, 2005 10:12 AM
