86 Civic CRX and a D16a6 Turbo........
Old Oct 8, 2002 | 07:53 PM
89 CRX SI's Avatar
Default 86 Civic CRX and a D16a6 Turbo........
how hard if you custom weld everything. This is for my winter beater so it dont need to look good.
Old Oct 8, 2002 | 09:00 PM
No More Civic's Avatar
Default Re: 86 Civic CRX and a D16a6 Turbo........ (89 CRX SI)
That's the 96-99? Civic Ex, SOHC VTEC, right?
Old Oct 8, 2002 | 09:11 PM
spettinger's Avatar
Default Re: 86 Civic CRX and a D16a6 Turbo........ (SlowCivicDX)
WTF? this is a single cam from an 88-91 with a turbo, into an 86 CRX.
should be a little bit of fun, as light as the 1st gen rexer is.
Old Oct 9, 2002 | 05:36 PM
89 CRX SI's Avatar
Default Re: 86 Civic CRX and a D16a6 Turbo........ (wreckedhatch)
no non VTEc 91 CRX SI motor with Turbo and Intercooler with Zydne.
does it fit in their with little mount mods?
Old Oct 9, 2002 | 05:47 PM
Mugen Dom's Avatar
welllll it will require some work....the d16a6 wont just mount up ull need to use the ew4 or d16a1 mount forget which one katman did try to do this and came upo short i talked to him a lil about it....on here...do a search i think i asked about it duno though look up threads by jdmb18hatch archived.....he showed how to mount the d16a1 tranny and the half shaft how to rig it up....lots of custom work....ull need to rig up teh radiator to sit more forward...all in al its more worth it to get a d16a1 and run the 86-87 pm7 ecu and electronics either way ull need to run the 86-87 ecu cause other wise ull need to some how rig up obd0 cause the 86 is a vacume advance distirbuter and has an external coil good luck
datsun71
Classic Hondas
Jun 30, 2013 05:05 PM
kennybintegra
Jul 23, 2006 11:34 AM
getnasty
Jan 21, 2006 07:55 PM
90ZCREX
Mar 8, 2005 01:43 PM
Engn
Jul 23, 2003 02:02 PM
