ctr nippon rebuild kit?
I really didnt want to start a thread for a lame as question....
but i did..
can any one give me info on this brand? is it cheap sh*t that's goin to brake?
the price is very reasonble including shipping.
here's the link http://www.ebay.com/itm/NIPPON-RACIN...sories&vxp=mtr
so yeh would b great if i could get some info bowt this brand or other brand's similer. cheer's
but i did..
why wouldnt you, are they that rubbish?
what about the ring's? that's the main thing im after i allready have ample amount of piston's.... buh mehhh look's to good to pass up haha
Yes rings are good..Idk I'd only use OEM gaskets and seals. Main things I wouldn't use is head gasket and bearings unless you check with them and everything is in spec
na nah i getch yah! im not lookn to run boost in the DA so ctr are pretty ideal for me.
hey dirty
how bowt the seals an gasket etc. heard anythink about them?
the piston's are almost half what you would pay for here. so i was thinking
of getn the piston's an ring's then selln the rest an make a bit of money.
as i am also with Dc4Lsteg, OEM is the way to goe!
those nippa's have poured millions into research and development for there product's
hey dirty
how bowt the seals an gasket etc. heard anythink about them?the piston's are almost half what you would pay for here. so i was thinking
The gaskets should be fine, there isn't much to a gasket, so you can't really mess it up lol. And nippon has always come through with stuff like that. I just remembered I used a Nippon oil pump/cover, and gaskets with my 4g63, worked great.
I'm using the NPR ITR conversion kit with the pistons,rings, king bearings main and rod.
I'm also using all the gaskets and they are legit. I'm doing and Ls vtec build. Happy trails man!!
so you are useing this gear atm? or you have purchesed it and applying it to your buil?
so really lookn to buy this in two more week's
still after info about experiance you guy's have had with this
dont think ill use the headgasket. but what about the bearing's? are they swt to use
and a noob question- Would i have to change fuel an air after installing high comp pistons?
or get it tuned?
Dont plan on geting any upgrades for awhile could i wait till then to tune
or get it tuned?
or get it tuned?
or get it tuned?
Sp00nFed EM1
15
Feb 13, 2008 08:41 AM
douglas_be
Feb 26, 2004 10:43 PM
