Exhaust material properties
Old Jan 20, 2012 | 02:02 PM
mhax's Avatar
Default Exhaust material properties
I've been talking with someone about thermal conductivity of material in car exhaust system. If you compare the aluminium to the stainless steel, the aluminium has around 200 W/m.K and stainless steel is around 20 W/m.K.
I think the aluminium pipe will lose more heat to the surrouding, resulting in a decrease of internal temperature as opposed to the stainless steel...is this right?
Old Jan 20, 2012 | 02:18 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Exhaust material properties
Internal temperature of what?
Old Jan 20, 2012 | 02:20 PM
mhax's Avatar
Temperature of the exhaust gas. From what i said, the exhaust gas velocity in aluminium pipe would be lower (because of a lower temperature) compared to a higher exhaust gas velocity in stainless steel pipe (because of the higher temperature). Is everything right?
Old Jan 21, 2012 | 06:17 AM
ddd4114's Avatar
Yes, but it's not going to be a night and day difference.
Old Jan 22, 2012 | 07:19 PM
mike703's Avatar
Also aluminum has 2 distinct advantages to steel. it weighs less and it will not rust. BUT it will crack before it bends and will need to be mig welded i believe. sorry if thats wrong but i call a mig a tig and a tig a mig all damn day long. Im sure theres a reason why we dont use aluminum though i just dont know why...
Old Jan 22, 2012 | 07:20 PM
mike703's Avatar
i thought of it probably because it gets hot and aluminum becomes kind of maliable and brittle.
Old Jan 23, 2012 | 04:20 AM
mhax's Avatar
Yeah but aluminium can dissipate heat way better than stainless steel, so stainless steel will get hotter. So i don't think the aluminium will get to the temperature where it gets maliable and brittle.
Old Jan 23, 2012 | 05:45 AM
The Grumpiest
I guess I have to ask, in the the real world, what difference does it make?
Old Jan 23, 2012 | 09:48 AM
turbohatch96y7's Avatar
I think aluminum sounds like **** that's why its not used from the manufacture. And its exspensive.
Old Jan 23, 2012 | 04:48 PM
hondamark35's Avatar
you don't want exhaust to dissipate heat. you want to get as much of that heat out and away from the underside of the car.
closer to the engine, the manifold.. could get hot enough to deform and likely blow out. Also aluminum doesn't rust but it does "oxidize." it can also be susceptible to some of the more corrosive components of exhaust, especially in the presence of moisture.
if you want to do better than stainless, Ti or Iconel. both high dollar but totally up to the task.
Old Jan 23, 2012 | 05:42 PM
ddd4114's Avatar
It has a measurable impact on baller status.
pizton
Honda CR-V & Element
Feb 15, 2014 09:38 AM
trancend
Welding / Fabrication
18
Oct 10, 2013 05:03 PM
PrjktCRX
Jan 18, 2005 09:50 PM
rough_draft
Nov 17, 2004 06:07 AM
