Side wall patch? Yes or no
Old Jan 20, 2012 | 08:49 AM
miamirice's Avatar
Default Side wall patch? Yes or no
So I have a rear tire on my s2000 with only about 2000 mi on it. It has a side wall puncture. About 1 cm, kind of a gash on the inner side wall. The tire is not for track use. It's a Dunlop star spec. Is this ok to patch or need I replace the tire?
Old Jan 20, 2012 | 09:05 AM
KandabashiDevil's Avatar
Default Re: Side wall patch? Yes or no
Replace
Sidewall patches are dangerous!
Old Jan 20, 2012 | 09:29 AM
ChristianL's Avatar
Originally Posted by KandabashiDevil
Replace
Definitely. As that tire heats up (especially when it gets warmer in a few months), that weak spot will grow into a big weak spot. Is the tire currently holding air, or is it a slow leak?
Old Jan 20, 2012 | 09:59 AM
toyomatt84's Avatar
Sanji
You should never patch a sidewall, just for future reference.
Old Jan 20, 2012 | 10:05 AM
macjac07's Avatar
Obviously you know not to patch the sidewall by now.....but also on any type of performance tire H rated or better a plug/patch combo is the best way to patch even a tread puncture....The reason you don't patch the sidewall is because that is where all your flex and tire roll is.
Old Jan 20, 2012 | 12:12 PM
miamirice's Avatar
Replace it is. As a follow up, the tire is a Dunlop star spec. 255/35 18". The sidewalls must be incredibly stiff but when I felt the rear getting squirmy I got off the highway and changed the tire. Well when the tire got pulled from the rim there was a pile of rubber inside equal to 2 handfuls and exposed steel at the sidewall/tread junction. of course the tire appeared normal on the inside. Just got me thinking you could have a tread puncture and plug it, never being aware of the damage done driving on a stiff sidewalled low profile tire.
citrus3000psi
May 26, 2008 08:29 PM
accordinglyevil
May 2, 2008 12:00 PM
poison
Oct 1, 2006 12:18 AM
Drag'nGT
Sep 30, 2005 07:40 AM
ck279
17
Feb 6, 2002 07:13 AM
